It is currently Wed Aug 20, 2025 11:52 am
PostPosted: Wed Nov 05, 2008 1:26 pm
Hi,
In a ham-fisted moment I have managed to strip the thread in the subframe where the rear radius arm retaining bracket fits! :(
Fortunately I can get to the hole with a drill easily with the wheel removed.
Any idea what size thread I should drill and tap it to without major engineering? :roll:
Thanks,
Brett.
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Wed Nov 05, 2008 3:17 pm
Best fix is to Helicoil it back to the original size. 5/16 unf
Dave
PostPosted: Wed Nov 05, 2008 3:44 pm
Thanks, just ordered a 5/16 UNF Heli-Coil kit from Bursons. Probably a handy thing to have lying around.
Brett Nicholson
1966 Austin Mini
1973 LR Series 3 88
PostPosted: Wed Nov 05, 2008 4:03 pm
A quick fic can be to drill out the hole and put a nut on the back, but only if it's one of those not in the box section! :lol:
You could also go up in bolt size, but that's a bit of a bodge! :?
Sir Alec! we are not worthy!
PostPosted: Wed Nov 05, 2008 5:57 pm
Don't pick up the helicoil kit Brett!
I've got a bag of 5/16th unf helicoils and the thread tap to do the job (3/8th UNF is perfect for the 5/16th UNF helicoils, luckily the only standard tap that matches a UNF helicoil actually...). Having a tap for the job means you only need the helicoil inserts (very cheap) and not the kit anymore.
Got exams till next week, and am up to my frickn eyeballs is engineering shite (so am stuck over the books), but you are most welcome to come around and grab them anytime.
PostPosted: Wed Nov 05, 2008 7:12 pm
I tap them out to 3/8 UNC if stripped, and fit a starter bolt.
5/16" (ie the stripped hole) is near enough to the right tapping size without getting into letter drills. :wink:
Users browsing this forum: Bing [Bot] and 78 guests
