It is currently Wed Aug 20, 2025 11:54 am
 Post subject: Oil Pipe replacement
PostPosted: Mon Nov 03, 2008 10:26 pm
Been up in Rockhampton for the weekend and noticed a Enzed shop a block down from the son's shop so thought I'd get the bits I needed to replace the bango pipe from the block to the oil filter. So armed with the Doc's parts list I head into the shop and described what I was after. For a start he didn't have the hose the Doc specified but produced a pretty blue coloured hose that he said was rated for hot oil to 250psi - the blue will match the spark plug leads :roll: Now the Doc's list called for barbed female connectors to go in the pipe so I figured instead of having them held with hose clips I'd get then crimped on. The guy tells me they don't need it as these particular fittings when pressed into the hose (which he did for me) the barbs bite into the rubber and have been tested to 10,000psi before they came apart - then the inner lining of the hose came away - not the barb.
Just thought I'd pass that info on - Hey Doc I'll be sending my nipples down for you to give them a tickle. :wink:
David L
PostPosted: Tue Nov 04, 2008 5:46 am
I no longer buy the 2 steel nipples from Pirtek etc, they are too dear. :lol:
Instead I buy brass ones from Bunnings, much cheaper, do the job fine and don't rust. 8)
PostPosted: Tue Nov 04, 2008 7:07 pm
Pic David :wink:
PostPosted: Thu Nov 06, 2008 9:45 am
David L
PostPosted: Thu Nov 06, 2008 3:32 pm
Ahhh now thats just too sexy to get dirty with oil and crap mate..... :wink:
PostPosted: Thu Nov 06, 2008 3:33 pm
Milatsmadmini
yummy mummy... thats a nice line ya got there Wombat... how much did it end up costing all together?
PostPosted: Thu Nov 06, 2008 4:34 pm
$55
David L
Users browsing this forum: Bing [Bot] and 70 guests
