It is currently Mon Aug 18, 2025 8:49 am
 Post subject: rust protectant
PostPosted: Mon Nov 10, 2008 4:58 pm
hey guys im getting ready to paint in the christmas holidays. and its going to be a bare metal job. just wondering if i can take back to bare metal now and cover with a rust protectant which doesnt require a spray gun as i dont have access to equipment untill the christmas holidays.
cheers leighton
PostPosted: Mon Nov 10, 2008 5:28 pm
por 15 is good or etch primer should do the trick also.
cheers TUCK3R
PostPosted: Mon Nov 10, 2008 6:50 pm
I used POR15's metal ready. Just brushed it on and left the car for a few weeks before painting. It leaves a fine coat of Zinc Phosphate (I think it is). Then just before primer I wiped the car down with a damp cloth to remove the residual material. Worked fine for me.
PostPosted: Mon Nov 10, 2008 6:55 pm
ok thanks guys.
what type of brush did you use was it a foam block type or the average bristly one?
cheers leighton
PostPosted: Mon Nov 10, 2008 7:21 pm
look at www.por15.com.au thats a really good site they even sent me out a free restorers catalouge. really helpful,will tell you everything you need to know.oh and they say a brush is fine or you can spray it to.
TUCK3R
PostPosted: Mon Nov 10, 2008 7:30 pm
theres a few similar threads on at the moment about this topic.. have a search...
read up about xtroll.. .aussie made version of POR15..
here's one:
http://www.ausmini.com/forums/viewtopic ... ight=por15
tim
PostPosted: Mon Nov 10, 2008 7:34 pm
yer i saw that looks like good stuff.. i just have alot of time on my hands at the moment and i figured why not start on bodywork. :)
PostPosted: Tue Nov 11, 2008 12:10 am
yeah time is definitely what you need when your doing bodywork!
i think http://www.rustbullet.com.au has been mentioned too as an alternative to por15, i think its a little cheaper and not affected by UV rays and can be painted straight over (but i would assume youd be priming over it no matter)
Users browsing this forum: No registered users and 283 guests
