It is currently Fri Aug 01, 2025 3:05 am
PostPosted: Fri Dec 12, 2008 9:15 pm
i have ajusted them as far as they can push to lock but i can still lift the handle. any help will be great as i need to fit central locking and alarm.
no door locks in the doors, keyless entry well soon.
PostPosted: Fri Dec 12, 2008 11:55 pm
I is a mookenik
im having this same problem with my clubby atm. i cant get the doors to lock, so im changing the door looks hopeing that might be a reason cause they were stuffed anyway. but i just noticed the other day i cant lock the door from the inside either and when u adjust them it just moves the locking handle to the lock position but u can disengage it then.
PostPosted: Sat Dec 13, 2008 9:08 am
I presume you are talking about lift up clubman type handles. Try loosening the 2 nuts that hold the outside handle on, this will loosen the bracket that adjusts the play in the handle - if it's to tight the lock won't engage.
PostPosted: Thu Jan 01, 2009 7:04 am
ok thanks i will give that a go.
