It is currently Tue Jul 29, 2025 3:38 pm
 Post subject: pipe flarer
PostPosted: Fri Jan 16, 2009 1:35 pm
I was interested in making up all new hydro pipes, fuel lines, brake lines etc for my car and wanted to know what sort of pipe flarer i need..
i have heard there are double flarers available, and a mate reckons for a good pipe flarer somewhere around $300...
Do i need a single flarer or a double flarer and as long as it says its for mild steel should it be okay???
What sort of price should i expect to pay (i dont think my mate knows what he is on about), any personal experiences from purchases or good brands recommended, Bad/poor quality brands Pm me.
Thanks
Brenton
PostPosted: Fri Jan 16, 2009 1:52 pm
I picked up a double flaring kit off ebay for 30 dollars. It did every line that needed to be done on my car including the 3/8th hydro lines.
I forgot to grease the thread in the tool before I used it (those cheap chinese threads ruin pretty easily) so I did some damage first up, it was replaced and this one worked perfectly (this time I made sure I lubed it up completely with moly grease).
It's still in good nick and I reckon it would easily do the job over and over again. You can get single flare tools from supercrap, but you need the dollies that come with the double flaring variety to complete your flares.
Don't be fooled with the hydro lines, they are single flare at first glance, but are in fact collapsed double flares (the double flare is folded back in on itself to make the sealing surface double the thickness of the tube). Easy to do.
Working on your carbs today btw :)
PostPosted: Fri Jan 16, 2009 2:08 pm
I purchased a kit from a tool store and found it didnt work very well on my brake lines. So I gave up and measured the brake lines and then had them made up at the local friendly brake shop.
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Fri Jan 16, 2009 2:19 pm
I bought a flaring kit from Coventry's and it works fine.
It's fully manual & you have to perform a second operation for the double flare (after you've done the first flare) but I wouldn't be without it. Can't remember the price but it was nowhere near $100 let alone $300 :shock:
PostPosted: Fri Jan 16, 2009 4:30 pm
Brake pipes must have double flares. :wink:
PostPosted: Fri Jan 16, 2009 5:37 pm
Ha ha thanks Mick.. thats AWESOME!!
thanks for the input and comments everyone,
i was thinking about either ones of these:
http://cgi.ebay.com.au/INDEX-TYPE-BRAKE ... 240%3A1318
Or if it stays cheap this one
http://cgi.ebay.com.au/AIRCON-REFRIGERA ... 240%3A1318
I think the earlier one is much better quality
Cheers brenton
PostPosted: Fri Jan 16, 2009 6:17 pm
The first one with the auto gripping pliers attached might give you problems, and the whole tool is stuffed if it does. I tend to shy away from a low quality integral tools such as this (as this is less than 50 dollars I will vouch it will be low quality metals), as one feature will depend on the rest of the features working together. If it was name brand and know, that would be another matter.
The second tool imho looks a better option as each part is generic and can be replaced independently, but you will get this kit for a much better price very easily. As I said, I got mine for 30 dollars, it has done everything I have asked of it so far (once the thread was greased) and they only get better from there.
PostPosted: Fri Jan 16, 2009 8:38 pm
I'm watching this thread also as this will be my next tool I purchase :wink:
PostPosted: Fri Jan 16, 2009 9:26 pm
Better than the 90c currently :shock: :shock: :shock: :shock: :shock:
What brand is yours Mick??
Good to know a proven brand
Thanks again Brenton
PostPosted: Fri Jan 16, 2009 10:34 pm
chin fung sung flung...or something like that....:lol:
Must be time for a how to...
My brother offered me a long loan of his Snap On branded double flaring kit, but the cheaper one has worked so well I didn't see the point of complicating things...
