It is currently Sun Aug 17, 2025 5:54 am
 Post subject: over heating
PostPosted: Wed Jan 21, 2009 8:20 pm
ok i want to know what would cause overheating when timing is right no air in radiator which is cracked head no blown head gasket...... would just sitting a car idling make it overheat???? because i start it and slowly it creeps up to hot???? thanks a lot guys in advance
1964 smooth roof panel van
1967 Mk 1 X-Police cooper s
1970 mini k
1975 leyland
PostPosted: Wed Jan 21, 2009 8:27 pm
High heel ninja
Just cause the gauge is reading hot does'nt mean the engine is hot, start the motor, let it get hot on the gauge, turn it off & squeeze the top radiator hose, if its rock hard the engine is hot, if you can squeeze the hose its not hot.
Doogie
PostPosted: Wed Jan 21, 2009 8:33 pm
righto thanks a lot doogie ill check it out and let you know
1970 mini k
1975 leyland
PostPosted: Wed Jan 21, 2009 8:38 pm
High heel ninja
Or your fan could be on backwards.
Doogie
PostPosted: Wed Jan 21, 2009 8:51 pm
lol no its on the right way........
1970 mini k
1975 leyland
PostPosted: Wed Jan 21, 2009 8:52 pm
Give Ash some flowers Nick .
Is the thermostat actually opening :?:
How old is the water pump? Is the impeller in reasonable condition?
Checked your thermostat??
PostPosted: Wed Jan 21, 2009 8:54 pm
Man i was so close!!
Yeah take it out and put it in boiling water from the kettle.
PostPosted: Wed Jan 21, 2009 11:08 pm
If u start it and it creeps up to hot straight away then the gauge/sending unit is faulty...theres no way it can overheat in 10 seconds.
PostPosted: Thu Jan 22, 2009 8:23 am
no it takes maybe 1 minute or a bit longer....
is there any other ways to check if there is a cracked head? there is no bubbles in the radiator and its not loosing water.
1970 mini k
1975 leyland
PostPosted: Thu Jan 22, 2009 8:48 am
Take the thermostat out and boil it to see if it opens, or just buy a new one.
Buy a thermometer that reaches 100 degrees, op then radiator cap, pop it in and start the engine. see if "HOT" actually means hot or not.
Normal engine running temps should be about 93 degrees (from memory... don't quote me) and on my gauge that is 7/8 to H.
Lillee - 1969 Morris Mini K
PostPosted: Thu Jan 22, 2009 12:30 pm
Hi all. I am having over hearing problem as well and losing water. How can you tell of the fan is facing the right way? I am suspecting is in the wrong way. I am currently using 74 degrees thermostat on a 1275 auto with the air con installed. will that be correct one to use?
PostPosted: Thu Jan 22, 2009 12:34 pm
PostPosted: Thu Jan 22, 2009 1:16 pm
Check to make sure you have the right radiator cap. Long Neck clubman radiators need a long neck cap.
If your's is a plastic fan, I am pretty sure that there is only one way to install the fan...
PostPosted: Thu Jan 22, 2009 2:04 pm
Yeah is a plastic fan. I bought the cap and the radiator from Karcraft so I am sure is the right one, is not a clubman, is a round nose.
Users browsing this forum: No registered users and 376 guests
