It is currently Mon Jul 21, 2025 9:13 pm
PostPosted: Wed Jan 28, 2009 4:20 pm
The original battery cover was looking a little 'tired'
So I bought a cheap plastice battery box from Supercheap ($12.95 on special)
Using the old box as a guide I marked out the shape and cut it out using a dremel - a hacksaw sort of did the job but the box was 'soft' and moved about a lot. Could use a Stanley knife but although it cuts easy it is hard to control and you can overcut easily.
I used the Stanley to trim off the burs and neaten up the curved bits.
The finished job.
David L
PostPosted: Wed Jan 28, 2009 4:27 pm
ginger ninja
ginger ninja
Looks great!
sports850 wrote:
PostPosted: Wed Jan 28, 2009 4:31 pm
Tomboss Breweros
Thats some nifty work. :roll:
kimini wrote:
Jimmyinamini wrote:
PostPosted: Wed Jan 28, 2009 5:07 pm
spiffy :wink:
'62 Morris 850 (Marion)
'69 Vanden Plas Princess 1300
'71 Wolseley 1300
'74 Austin 1300 Countryman
'94 XJ6 Sport 3.2
'04 Rover 75 CDTi
PostPosted: Wed Jan 28, 2009 6:20 pm
just like a bought one!
PostPosted: Wed Jan 28, 2009 6:48 pm
I'm Bert , where's Ernie
very nice! will have to make one myself now!
just a question, why did you cut out a semi-circle hole after where the lead goes through? (In the last pic next to the bolt)
'73 clubby s "cryo" - sold
Operation Evil Sesame Street!
PostPosted: Wed Jan 28, 2009 7:35 pm
That was on the original and gives room for the end of the J hook of the hold down to stick out and access for the cover strap it clip on the other hole in the metal tab next to the battery compartment
David L
PostPosted: Wed Jan 28, 2009 7:36 pm
Interesting..
On a shell I just recently aquired, the old battery tray was cut out, and a new annealed one made to suit that style battery box (plastic liner and lid)... Lifty little idea anyway..
You can't drive your shares on the weekend...
PostPosted: Wed Jan 28, 2009 9:30 pm
I have to do this soon, what kinda set up does a mini use to secure the battery? and also does the cover just push on top of the battery?
blokeinamoke wrote:
PostPosted: Wed Jan 28, 2009 9:39 pm
Battery Hold down and cover strap
David L
PostPosted: Wed Jan 28, 2009 9:44 pm
Wombattery covers Schmicko
PostPosted: Wed Jan 28, 2009 9:49 pm
blokeinamoke wrote:
PostPosted: Wed Jan 28, 2009 9:52 pm
The blue writing in my last post is a link
David L
PostPosted: Sat Jan 31, 2009 3:40 pm
the hold down, does it go longways or across the battery?
blokeinamoke wrote:
PostPosted: Sat Jan 31, 2009 4:30 pm
Longways with two short J bolts down to the holes on the sides of the box each end
David L
