It is currently Fri Jul 18, 2025 7:02 pm
 Post subject: still overheating
PostPosted: Sun Mar 15, 2009 9:57 am
well i have changed the thermostat and looked for leaks the radiator has been serviced 2 years ago should i re clean it. i have flushed it with radiator clean.
the water is evaporating from somewhere any ideas ?
its sitting on hot most of the time but sometimes doesnt and sits ok.
PostPosted: Sun Mar 15, 2009 1:02 pm
reverse flush the radiator. Mine was doing that too, after the new thermostat as well, so I took the radiator out, flushed it both ways, with hot water and cold 4 times till the water ran clear, then put it back in, new hoses and clamps and a new radiator cap. Now shes runs normal even when flat out on a 40 degree day. Turns out my radiator cap was causing the main problem. For an extra 50 bucks spent on hoses, clamps and a cap, its still cheaper than breaking down on the side of the road. Good luck!
88 Rover 1.3i "Reggie"
99 Rover 1.3i “Grover”
17 Mini Clubman JCW “Noddy”
