It is currently Fri Jul 18, 2025 7:13 pm
 Post subject: still overheating
PostPosted: Sun Mar 15, 2009 9:57 am
well i have changed the thermostat and looked for leaks the radiator has been serviced 2 years ago should i re clean it. i have flushed it with radiator clean.
the water is evaporating from somewhere any ideas ?
its sitting on hot most of the time but sometimes doesnt and sits ok.
PostPosted: Sun Mar 15, 2009 1:02 pm
reverse flush the radiator. Mine was doing that too, after the new thermostat as well, so I took the radiator out, flushed it both ways, with hot water and cold 4 times till the water ran clear, then put it back in, new hoses and clamps and a new radiator cap. Now shes runs normal even when flat out on a 40 degree day. Turns out my radiator cap was causing the main problem. For an extra 50 bucks spent on hoses, clamps and a cap, its still cheaper than breaking down on the side of the road. Good luck!
88 Rover 1.3i "Reggie"
99 Rover 1.3i “Grover”
17 Mini Clubman JCW “Noddy”
Users browsing this forum: No registered users and 119 guests
