It is currently Wed Jul 23, 2025 2:40 am
PostPosted: Sun Mar 22, 2009 4:22 pm
Refurbishing a S/H heater 1973 model - plastic body - from a Clubman - fan works OK but when I pressure tested the heater matrix there is a pin hole putting out a fine stream.
Is it worth fixing or getting it new matrix - or would all I be buying is a reconditioned one anyway?
PostPosted: Sun Mar 22, 2009 4:34 pm
get your soldering iron out
I reckon fix it...
PostPosted: Sun Mar 22, 2009 4:38 pm
It's the easiest thing in the world to fix it, and the cheapest thing to have repaired by a radiator shop.
Normal electrcal solder (60/40 lead/tin) is just fine for the job if you can get enough heat into it.
PostPosted: Sun Mar 22, 2009 4:40 pm
Dismantle > Inspect > Repair or Replace depending on condition.
If the core is rotten it will need replacing.
If it is just a pin hole and everything is solid just solder it up.
PostPosted: Sun Mar 22, 2009 4:41 pm
Tomboss Breweros
simon k wrote:
I reckon fix it...
Ditto, i fixed one about 4 years ago, still going good :)
kimini wrote:
Jimmyinamini wrote:
PostPosted: Sun Mar 22, 2009 4:45 pm
I'm not aware of anyone who has NOS heater cores for the Mini range. If someone knows of a source please post it. Otherwise it's solder the current one, or get a radiator place to fabricate a new one ($$$ !!!).
