It is currently Sun Aug 17, 2025 5:06 pm
 Post subject: Interesting ......
PostPosted: Sun Apr 19, 2009 9:21 pm
1st up got the passenger door off - has 3 of the wedge shaped alloy washers 2 on the bottom and 1 on the top :?
2nd the back retainer on the bottom hinge was a bolt - that snapped off while being undone :evil:
3rd thing I bolted the refurbished S/H drivers side hinges to the body with new plastic/rubber(?) gaskets. First I tightened the nuts evenly then the rear ones first - still get the same result - the hinges dont sit tight against the body. The back (near edge of the door) is away from the body - the top one not much but I can move the gasket with my finger nail. The bottom one there is about 1mm gap. The nuts are tight as I can do them and the hinge body is tight and no movement. Anyone else have this happen?
PostPosted: Sun Apr 19, 2009 9:25 pm
Under the rear studs I used a large panel washer to spread the load out. I still put a champhered washer where appropriate but used the washers to reduce distortion all that weight can have on the door skin.
The gaskets I used were made of bitumised card.
PostPosted: Sun Apr 19, 2009 9:33 pm
David,
Here is a diagram of the way the hinge bolts, studs and washers should be. it is correct!
Note stud length and washer and spacer positions are shown for both upper and lower hinges.
Hope this is of some use to you.
Dave
PostPosted: Sun Apr 19, 2009 9:54 pm
Thanks Dave - that's a great help. The S/H drivers side hinges I have have bolts instead of screws for the front door side hinge and there was a stud in both positions on the front half of the bottom.
It is my original passenger side bottom door side rear that had a bolt instead of stud.
Don't you just love working on Minis :roll:
PostPosted: Mon Apr 20, 2009 1:31 pm
What a slut those two inner bolts are to get off, especially if you have road dirt jammed up around them.
PostPosted: Mon Apr 20, 2009 2:07 pm
I have a Sidchrome 7/16 A/F ring/open ender, with the ring end seriously ground away so it's way thinner. Also it's bent up a little. Works for me... :wink:
PostPosted: Mon Apr 20, 2009 2:12 pm
How many more cheap 7/16 ring spanners do I need so I can butcher them? :P
One for brake lines - now one for door hinges - anymore?
PostPosted: Mon Apr 20, 2009 2:18 pm
I have a selection of 1/2 inch spanners as well as 7/16 spanners, some of the 1/2 inch ones have been bent to accomadate single bolts such as the one at the bottom of the clutch housing which is a bitch to get at with the motor in the car.
Youll end up with a toolkit specific to the car, a small set of spanners you can put in a pencil case and throw in the boot.
PostPosted: Mon Apr 20, 2009 3:18 pm
I have a 1/2" one for the 2 bottom bolts in the clutch wok, just put the ring end in the vice, heat shank next to it and put a 45° bend in it. :P
And, another 1/2" one for the mech fuel pump nuts- grind the ring end thin, cut in half, weld at 90° so it is L shaped. 8)
PostPosted: Mon Apr 20, 2009 7:22 pm
I cut the cast web off the fuel pump so that the spanner has more turn from above. :wink:
PostPosted: Mon Apr 20, 2009 9:07 pm
This space for rent
I fitted an electric one :roll:
PostPosted: Mon Apr 20, 2009 9:14 pm
I like the fuel pump to stop when the motor stops. :wink:
PostPosted: Mon Apr 20, 2009 9:15 pm
Can be arranged with some more wiring.
PostPosted: Mon Apr 20, 2009 9:20 pm
I know, but I like things to be simple and reliable. There is no point in adding more weight and making things more complex when it is not needed. The stock fuel pump can do a good job and is simple.
PostPosted: Mon Apr 20, 2009 9:25 pm
the gas lock off in mine weighs about as much as a finger nail so not much different, and you can time it so it runs for a while before you turn the engine over for that high tech feel, then when it breaks down on a rainy highway i agree with you fully
Potato
Users browsing this forum: No registered users and 130 guests
