graham in aus wrote:
Those adjusters are the worst thing about front drums
Drums can be good brakes, but if these adjusters are loose and worn in the back plate, they will 'self adjust' off!
The opposite is they are cooroded solid and or the square for the spanner is rounded.....Grrrr
There used to be a kit to repair these, never used one, but I think it was a replacement adjuster with a threaded nut on the back to lock the aduster in place once set.
Anybody seen or used one? Would have been a good project for David Rosenthal, but it seems he's leaving us
Drums
ARE good brakes if you keep them
in good working order. Yes they require more upkeep than disc's but as long as you're not racing, or being silly coming down a big hill, even then with a skilled driver they are quite up to the task. Just not as capable as disc brakes.
Never heard of a repair kit for the adjusters though. Would be nice if there is a solution out there.
