It is currently Sat Aug 09, 2025 1:57 pm
what to use when replacing a gasket eg. water pump gasket
just the gasket, put a slither of oil on it to lube it up and make it nice and slick! 0%  0%  [ 0 ]
gasket and gasket goo on both sides 71%  71%  [ 27 ]
just gasket, if both pump and block are completely clear it is the right thing to do 5%  5%  [ 2 ]
just the gasket goo... 3%  3%  [ 1 ]
let a bunch of asparagras form an ultimate protective slime, completely imperveous to water and heat! 21%  21%  [ 8 ]
Total votes : 38
 Post subject: gasket poll!!!
PostPosted: Fri May 08, 2009 12:10 pm
Milatsmadmini
woo..... a little off beat, just want others opinions...
PostPosted: Fri May 08, 2009 12:16 pm
3J or loctite 515 depending on location
- 1962 Beige Delight club car, Rebuilding.
- Motorkana Special
- Minor Mishap, 1958 Morris Minor
-- Last ever Tea Lady at Longbridge--
PostPosted: Fri May 08, 2009 12:17 pm
i did gasket and goo, but then i'd never done it before and there was goo everywhere. I still don't know if I did it right, but no leaks so far (5 months)
PostPosted: Fri May 08, 2009 12:18 pm
I just use a gasket, but make sure both surfaces are as close to perfectly clean as they can be. Wont last as long but will be a lot easier to clean and replace with a new gasket.
PostPosted: Fri May 08, 2009 12:40 pm
Tomboss Breweros
I like loctite no. 3 aviation gasket sealer for water gaskets, use it sparingly on both sides of gasket and it's not too messy, cleans up ok on disassembly.
kimini wrote:
Jimmyinamini wrote:
PostPosted: Fri May 08, 2009 12:55 pm
unfortunately, Araldite takes too long to cure............................... :lol:
PostPosted: Fri May 08, 2009 1:03 pm
I love that stuff....It should be the gasket alone is enough, but if you have it there then why not stick some on rather than hope that some clown hasn't jimmied the pump off with a crowbar and damaged the journal.
PostPosted: Fri May 08, 2009 1:09 pm
This space for rent
I use a very thin film of Permatex gasket sealant, only because I tend to find the mating surfaces for water-jacket items are corroded and the gasket is no longer sufficient to seal by itself.
PostPosted: Fri May 08, 2009 1:10 pm
Mick wrote:
I love that stuff
Good if used sparingly. Just need to remember when applying it to gaskets, your'e not icing a cake!
PostPosted: Fri May 08, 2009 1:21 pm
Go the asparagus!!
PostPosted: Fri May 08, 2009 2:15 pm
I agree.
I use nothing on head and manifold gaskets, and Loctite 515 Master gasket on everything else. It doesn't leak, gasket or no gasket... great stuff.:lol:
PostPosted: Fri May 08, 2009 5:28 pm
Threebond 1215. I have used them all and this is the best.
Have a Nice Day.
PostPosted: Fri May 08, 2009 5:31 pm
Milatsmadmini
where does everyone get these things??? ive trolled the bunnings and auto stores most of the arvo...cant find any cept the peratex? stuff at supercrap.... anyone?
PostPosted: Fri May 08, 2009 5:37 pm
Bursons.
Have a Nice Day.
PostPosted: Fri May 08, 2009 5:40 pm
Repco at Camperdown seemed to have a decent range of Loctite when i bought mine - the only reason i remember is that there were so f-ing many of them, i didn't know which was the best one to pick.....so can't say whether they have the one mentioned in the thread...the one i bought came in a green box!! :)
