It is currently Sat Jul 19, 2025 10:29 am
 Post subject: 1-3/4 su question
PostPosted: Fri May 22, 2009 8:12 pm
I have found a couple of su's, and was wondering if anyone could shed some light on them. meaning good, bad, etc, etc.
the numbers stamped on the bodies are;
* AUD425f
* AUDPDC2
* AUD9
Any ideas? Not knowing su's, are any of them hif44's?
mooo, I'm a pig!
PostPosted: Fri May 22, 2009 8:42 pm
not sure if this will help you with the numbers but this is a great thread for identifying carbys. http://www.ausmini.com/forums/viewtopic.php?t=53394.
TUCK3R
PostPosted: Fri May 22, 2009 8:44 pm
looking at the pics, I am pretty sure that they are hs6.
mooo, I'm a pig!
PostPosted: Fri May 22, 2009 9:09 pm
the carbies are listed on ebay. item # 170334469985.
Still on the cheaper side at the moment.
mooo, I'm a pig!
PostPosted: Fri May 22, 2009 9:14 pm
They are all HS6.
PostPosted: Fri May 22, 2009 9:19 pm
Yep HS6 but has an additional hole for the airfilter as its from Marina
PostPosted: Fri May 22, 2009 9:20 pm
go good on a 998?
mooo, I'm a pig!
PostPosted: Fri May 22, 2009 9:23 pm
With a hot cam, some head work, bigger valves etc, nice flowing manifold, a decent set of flowing extractors, some more compression, a decent dizzy graphed to suit & maybe a bell mouth inlet inside a really large un-restricted air filter ayys & yep,,, would work great... for a small bore :-)
micowen wrote:
go good on a 998?
What, all three of them? :lol:
In my view one of them would be way too much unless it was a very worked engine.
PostPosted: Fri May 22, 2009 9:26 pm
i could put 4x of them onto a small bore twin cam donk :-)
PostPosted: Fri May 22, 2009 9:30 pm
motor was supplied by a nice boy here on ausmini. It is a 998 with an 1100 crank, mild cam (dont know specs), and worked head.
mooo, I'm a pig!
PostPosted: Sat May 23, 2009 8:50 am
good thing for your motor...
