It is currently Mon Jul 28, 2025 3:25 pm
 Post subject: Wheel and brakes!
PostPosted: Sun May 31, 2009 9:29 am
Hi there, i think i know the answers to this question but will ask anyway.
Is it possible to fit disk brake with standard 10' steel wheel and no wheel arches?
:oops:
Louis
PostPosted: Sun May 31, 2009 9:36 am
This space for rent
Yes, you need LS-offset Contessa's or a wheel with similar offset.. and then they'll only fit over Cooper S discs.
PostPosted: Sun May 31, 2009 9:45 am
High heel ninja
A standard steel wheel will fit over S disc brakes, LS narrow offset contessa hit the caliper, you need to attack the caliper with a angle grinders to get them to fit over them.
Doogie
PostPosted: Sun May 31, 2009 10:46 am
the old cooper (not S) disc's have the same off-set as a standard mini.
they can be made to work very well with the newer types of break linings.
PostPosted: Sun May 31, 2009 12:04 pm
I'm looking at the same sort of thing - perhaps using the Cooper S replica Alloy wheels from Minisport - I think 165 tyres might be the killer though
'62 Morris 850 (Marion)
'69 Vanden Plas Princess 1300
'71 Wolseley 1300
'74 Austin 1300 Countryman
'94 XJ6 Sport 3.2
'04 Rover 75 CDTi
Users browsing this forum: 1071 S and 86 guests
