It is currently Fri Jul 18, 2025 7:03 pm
 Post subject: windsrceen wipers
PostPosted: Thu May 28, 2009 8:51 pm
This maybe simple yet stupid, but i was wondering if someone can tell me how to remove the windscreen wipers, i have tried but i dont want to break anything. Any help would be great.
Thanks, Ash.
PostPosted: Thu May 28, 2009 8:56 pm
High heel ninja
Do you mean the wiper arms? You need to get a flat blade screw driver and pop them off the splines, not a hard job, but can be fiddly.
Doogie
Hi Ash,
you will see the spring inside tends to tilt the bottom bit on the splines.
grab the bottom bit with fingers then push the top bit in at the hinge point, pull upwards and it'll all slide off.
PostPosted: Thu May 28, 2009 8:59 pm
Yeh, the wiper arms, thanks for the info, will give it a go tomorrow, thanks.
