It is currently Tue Jul 29, 2025 11:53 pm
 Post subject: Average running Temp
PostPosted: Thu Jun 18, 2009 1:53 pm
Hey just wondering the average running temp of a worked 1400cc Aseries engine? also average oil pressure ?
PostPosted: Thu Jun 18, 2009 2:08 pm
How worked?
2008 Prado GXL
PostPosted: Thu Jun 18, 2009 2:21 pm
1275 Forged Mini Cooper 'S' Rockers
Nitrided Rocker Shaft
Alloy Valve Spring Retainers
Double Valve Springs
Rimflo Stainless Steel Inlet and Exhaust Valves
Head Ported as in Visard Book for 1400cc Specification
MG Metro Turbo Head Gasket
74mm Omega pistons
45mm Side Draft Weber on Custom Manifold
Uni Filter Pods and Velocity Stacks
Lightened, Balanced and Shot Peened Con Rods
Wedged, Lightened and Nitrided Crankshaft
Lightened Flywheel
Orange Racing Clutch and Mating Diaphragm
MG Metro Turbo Oil Pump
Center oil pick up
1275 GT Diff and Full Universal Drive Shafts (Internal)
Fred Sayer LSD conversion on Mini K 3.66 ratio diff - brand new
Belt Drive Timing Belt and Gears
RE13 Cam
Heavy Duty Cam Followers
Polished Pushrods
13 Row oil Cooler
High Flow two-core competition radiator
PostPosted: Thu Jun 18, 2009 2:27 pm
74mm Omega pistons
Lightened Flywheel
Center oil pick up
RE13 Cam
Polished Pushrods
13 Row oil Cooler
for that motor.... I bet the average is hotter than it should be
PostPosted: Thu Jun 18, 2009 2:48 pm
Water temp should run on the thermostat,,, so 82 deg
oil pressure (while running along) should be 60-ish ,,,Hot (as in up to running temp)
& approx 25+ while idleing,,, hot (again as in up to running temp)
Users browsing this forum: No registered users and 49 guests
