It is currently Sat Aug 02, 2025 9:52 pm
 Post subject: MG 1275 in a mini?
PostPosted: Sat Jun 20, 2009 10:09 am
Milatsmadmini
is it possible to fit it? yes i know its a rear wheel drive set up etc... but can it be taken off the box and adapted to fit a transverse box?
PostPosted: Sat Jun 20, 2009 10:20 am
From my understanding it basically requires an MG 1275 crank and sump as well as the revelant seals and things.
Mike
PostPosted: Sat Jun 20, 2009 10:23 am
Mike
Or in this case a 1275 Mini Crank and all the other bits. I am pretty sure it can be done.
Dicko
PostPosted: Sat Jun 20, 2009 10:25 am
Sorry read that the other way around - my mistake
Mike
PostPosted: Sat Jun 20, 2009 10:58 am
if you've got one, sell it to someone with a morris minor, and that'll pay for a transverse one
PostPosted: Sat Jun 20, 2009 11:14 am
Usually the transfer is in the other direction....mini to MG/AH..
We're pretty lucky when it comes to availability of 1275 blocks.
PostPosted: Sat Jun 20, 2009 11:22 am
that's what I mean ;)
PostPosted: Sat Jun 20, 2009 11:30 am
Matt if you want a 1275 transverse block & caps, PM me. :wink:
PostPosted: Sat Jun 20, 2009 12:21 pm
I think he needs the crank first!
PostPosted: Sat Jun 20, 2009 12:34 pm
I am offering him a swap
Mike
PostPosted: Sat Jun 20, 2009 4:49 pm
Milatsmadmini
i am not in possesion of this engine at the moment, it will be coming out of a working/driving car, but it is readily available to me... so you think best bet is to get it, sell it, then pay for a mini 1275 block?
PostPosted: Sat Jun 20, 2009 4:59 pm
The crank is the important bit. I will swap you a 1275 mini crank for the 1275 MG crank - block and crank if you like
Mike
PostPosted: Sat Jun 20, 2009 5:03 pm
Milatsmadmini
Mike
definately noted.
ill let you know what i decide Mike,
-Matt
Users browsing this forum: fuzzy-hair-man and 90 guests
