It is currently Sun Aug 03, 2025 12:20 am
PostPosted: Thu Jul 23, 2009 7:03 pm
im worried only just started happening , changes up gears no problems but down into 3rd or 2nd it crunches and also first is very hard 2 find not sure if its normal or not??? i tryed moving the carpet bhind the clutch pedel but dont think it made a difference :(
PostPosted: Thu Jul 23, 2009 7:06 pm
Is your clutch fluid level ok?
Image Image
PostPosted: Thu Jul 23, 2009 7:09 pm
havent checked but i will wen i find a torch
PostPosted: Thu Jul 23, 2009 8:42 pm
what are your revs when you're changing down (if you have a tacho)? try changing down a little later and see how you go. otherwise, if still crunching at low revs your clutch needs adjusting, or your synchros are wearing out (expensive...)
78 Leyland Mini - Prince
PostPosted: Thu Jul 23, 2009 9:47 pm
ok its not flud level, and it now only seems 2 be doing it sometimes, plus the clutch feels soft n then hard like it changes from when it warms up or stop and starting i guess dunno if thats rite?
PostPosted: Thu Jul 23, 2009 9:49 pm
Probably a broken offf ball on the bottom of the clutch arm
Pull the arm off the end of the engine & inspect the condition of the ball on the bottomn of it
