It is currently Tue Jul 29, 2025 8:17 pm
 Post subject: RE13 vs 998 Cooper Cam
PostPosted: Fri Jul 24, 2009 10:04 am
ginger ninja
ginger ninja
Hi all, I have a friend who is after specs for the above two cams.
I did a search and found that the knowledgable Doc said that the RE13 'has about 274° duration and .290" lift at the lobe' and using 1.5 rockers adds HP on the bigger motors.
Does anyone have the specs handy for the 998 Cooper cam?
sports850 wrote:
PostPosted: Fri Jul 24, 2009 10:06 am
I don't have any specs, but can you do more numbers and power and engine talk?
I like it.
:D
PostPosted: Fri Jul 24, 2009 1:10 pm
High heel ninja
You should talk to the silver haired fox at Morgan Park, im sure he'll LOVE to talk cams with you. :wink:
Doogie
PostPosted: Fri Jul 24, 2009 1:11 pm
ginger ninja
ginger ninja
Doogie
He'll get all technical and I'll get all flustered :oops:
sports850 wrote:
PostPosted: Fri Jul 24, 2009 1:16 pm
High heel ninja
jess wrote:
Doogie
It's alright, he'l offer to cure your flusterness.
PostPosted: Fri Jul 24, 2009 1:44 pm
doogie wrote:
jess wrote:
Doogie
from what I've heard, that's not the only thing he'll offer
PostPosted: Fri Jul 24, 2009 1:49 pm
ginger ninja
ginger ninja
People!! Back on topic please. None of this in Mini Chat, don't make me get the whip out! (again simon!!) :twisted:
So anyhoo, does anyone have an answer for my friend?
sports850 wrote:
PostPosted: Fri Jul 24, 2009 2:33 pm
Supercharged
no but i'd like to hear more about you and whips. :mrgreen:
PostPosted: Fri Jul 24, 2009 3:33 pm
This Link says a 998 Cooper Cam was an AEA630, with a duration of 230º. The major difference over standard was extra lift. That's a lot less than an RE 13...
It also says that the 997 Cooper had a hotter cam. So, go the RE 13, or the 997 Cooper cam, then the 998 Cooper cam.
This is the best explanation I found... Has lift, duration, etc. :)
PostPosted: Fri Jul 24, 2009 4:03 pm
ginger ninja
ginger ninja
Thank you Tadhg! You are a legend!
sports850 wrote:
PostPosted: Fri Jul 24, 2009 4:49 pm
I agree. The 998 Cooper cam was much the same as a stock 1098 cam. Tame as. :lol:
997 Cooper cam was a good thing, but there are better cams about now.
PostPosted: Fri Jul 24, 2009 8:18 pm
I'm now putting a 998 motor in Marcia rather than what I expected which will have to wait. The 998 will have a RE13 cam but as you have said in your original post a 1.5 rockers will not work well in a 998 motor no matter what cam he/she uses
