It is currently Sat Aug 16, 2025 1:31 am
 Post subject: how well will it go
PostPosted: Sat Aug 01, 2009 8:06 pm
ok i want to no how well a 1100 will go with a re13 cam and a 12g940 head (not worked) with a 1.5 carbie on it with LCB extractors and a 344 diff
PostPosted: Sat Aug 01, 2009 8:09 pm
This space for rent
Not a bad combination, it'll do pretty well. It'll do better with twin 1-1/4"s, you get good torque and better breathing at high revs. A single HS6/HIF44 will get you the same breathing, but torque will suffer a little. The single 1-1/2" SU isn't quite enough to get the most out of that engine.
PostPosted: Sat Aug 01, 2009 8:11 pm
ok so if i stick a 45 mm webber on it will that fix it
PostPosted: Sat Aug 01, 2009 8:17 pm
This space for rent
Quite possibly overkill on an 1100 unless it's worked lots, but at least it won't be the weakest link :lol:
PostPosted: Sat Aug 01, 2009 8:18 pm
ok cool cool thanks alot will stick that in my car now :) wont go webber go something else figure it out
PostPosted: Sat Aug 01, 2009 9:30 pm
High heel ninja
A 12G940 head won't just bolt onto a 1100 motor, you need to scallop the block & pistons to clear the valves. A 3.6 or 3.7 diff is more 1100 friendly.
Doogie
PostPosted: Sat Aug 01, 2009 9:53 pm
FFS its spelt Weber not webber.
No relation to the latest winner of the German Grand Prix :roll:
PostPosted: Sat Aug 01, 2009 10:11 pm
Doogie
I'm sure you can run a 940 head on a 1100 but with a 940 head gasket just dependant on how much has been shaven off the head prior. I can't tell you how it would go but my 1152 with a RE13 & LCB with a maxed shaved 202 head works well with a HIF44 & have had 45.2 bhp at the wheels. I/we have a 3.44 diff and I would prefer a 3.6 or 3.7 as Doogie has said.
PostPosted: Sat Aug 01, 2009 10:52 pm
I no it won't just bolt on u have to machine the water pump and pocket the bore to allow the valves to miss the side of the bore all stuff I can do with a very experianced person watching over my shoulder
PostPosted: Sun Aug 02, 2009 9:24 am
High heel ninja
Water pump?????
Doogie
PostPosted: Sun Aug 02, 2009 1:03 pm
12G940 is too big IMO. Same with the 45mm Weber, you'll lose low down torque. Bigger is NOT always better...
Work a proper 202 or get a 295.
As said with that combo. you'll be looking around 50HP at the wheels tops.
Put a 1 3/4" SU on it. or 40mm Weber.
PostPosted: Sun Aug 02, 2009 2:02 pm
I hate these threads.
