It is currently Tue Aug 05, 2025 2:40 pm
PostPosted: Sun Aug 02, 2009 3:51 pm
hi everyone
I have only got a little over 9v at he voltage stabilizer so my oil light etc wont work.
My battery has 12.5v
I am assuming its a bad earth does anyone know where the earth point for that particular circuit is?
any other help will be appreciated.
blokeinamoke wrote:
PostPosted: Sun Aug 02, 2009 4:06 pm
The oil light does not run through the voltage stabilisor.
The voltage stabilisor is on the feed to the gauges. The gauges need a lower voltage without dips and peaks. The voltage into the voltage stabilisor is straight from the battery so is ~12.5 to 14 v and the voltage out of the voltage stabilisor is about 9v.
(or I could be totally wrong)
PostPosted: Sun Aug 02, 2009 4:11 pm
10 volts is what is supposed to come out of the stabilizer but I have less than that going into the stabilizer(should be 12 volts)
blokeinamoke wrote:
PostPosted: Sun Aug 02, 2009 6:35 pm
I havent had a chance to prove my alternator yet because I havent had the car on the road yet. All the other electrics work just those within the dash... but there is power...just not enough..
I have done a search and some reading but am still miffed...
blokeinamoke wrote:
PostPosted: Sun Aug 02, 2009 11:19 pm
ok,
I found a blown fuse so I now have an alternator light that comes on and goes off once the engine starts.
I still have no oil light , I put my multimeter on oil sender and there was 12 volts there. I tested the back of the dash panel and there was no power at the oil light.
The temp gauge wont work still, I tested the brass screws behind the temp gauge in the dash and there was no power there either.
I tested the three prongs on the stabilizer and the had, 12 v 10v earth so theres nothing wrong there.
I joined the rear loom earth to the neg side of the battery in case it was a bad earth problem but to no avail.
I also fiddled with the earth in the engine bay.
Does the alternator light use the same power source as the temp and oil gauges?
blokeinamoke wrote:
PostPosted: Tue Aug 04, 2009 12:01 am
It turned out to be
An earth problem
A broken 10v feed wire
A blown fuse
Possibly but less likely a broken voltage stabilizer
God I hate my mini some days
blokeinamoke wrote:
Users browsing this forum: winabbey and 84 guests
