It is currently Tue Jul 22, 2025 3:58 am
 Post subject: Pudding Stirrer on Van's
PostPosted: Thu Aug 06, 2009 4:08 pm
Is this anatomically correct?
http://www.ausmini.com/forums/viewtopic.php?t=55809
Did all vans come with a pudding stirrer?
2008 Prado GXL
PostPosted: Thu Aug 06, 2009 4:13 pm
That woud have yes. 4 speed synchro (same box as a Mini K, same case as a Mk2 Cooper S) with pudding stirer diff housing (different to an 850).
I would take a pic of the box, but I sold the one I had that isn't in a car.
PostPosted: Thu Aug 06, 2009 4:22 pm
Ok, while we're on the subject whioch one's came out with rear seats, or was it an option?
2008 Prado GXL
PostPosted: Thu Aug 06, 2009 4:25 pm
traveller /estate
was an option kit very early :?:
PostPosted: Thu Aug 06, 2009 4:31 pm
Travellers/Estates/Countrymans were never sold new here.
It was fitted by dealers and aftermarket kits available back in the day, but very rare.
PostPosted: Fri Aug 07, 2009 1:51 am
PostPosted: Fri Aug 07, 2009 6:24 am
I had a Clubby van in 1987 and it had remote change as original
David L
PostPosted: Fri Aug 07, 2009 8:57 am
Gee those rear seats look really comfortable. :wink:
2008 Prado GXL
PostPosted: Fri Aug 07, 2009 9:08 am
Better than the spare tyre my kids sat on :roll:
David L
PostPosted: Fri Aug 07, 2009 9:12 am
What year?
PostPosted: Fri Aug 07, 2009 9:24 am
Gee those rear seats look really comfortable. Wink
Are those even vinyl???! Looks like two pressed pieces of sheetmetal!!! :lol:
Posture care chair company eat your heart out! That'll stop 'em slouching! :lol:
As for the magic wand, there was an early clubby van for sale on ebay recently (71-72?) and it had the magic wand and the centre speedo.
The modern motor road test in the "mini minor downunder" book that covered the launch of the clubman also mentioned that "only the economy model 1100" retains the centre speedo - would the magic wand be something that they phased out once they stopped producing the 1100 motors in oz? (ie around 1973-74?)
+ Too many other classics
PostPosted: Fri Aug 07, 2009 10:03 am
poeee wrote:
What year?
Pre 1987 :roll: .. No idea - original engine (matching numbers ) and I had to replace the rubber and steel sandwich plate thing between the housing and the diff so had to pull the remote housing out so it all looked original - press gear stick hole - no hole at firewall etc
David L
PostPosted: Fri Aug 07, 2009 10:04 am
The magic wand was used with the remote type gearbox on vans. When they switched to rod change boxes it moved to the more usual position.
The same change was used in Mokes around the same time.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Fri Aug 07, 2009 12:41 pm
Pretty sure the rubber sandwich between the remote and diff housing was only used on Morris 1100.
Pete
 Post subject: van
PostPosted: Fri Aug 07, 2009 1:17 pm
Hiya,
My 72 van has the central speedo and magic wand type hole (I don't have the motor or gearbox).
As an aside, speedo surround should also be black, I believe.
cheers! jon
