Not sure what you mean, there should be a small (hardly even noticable) spark at the points when they open. The lead that goes from the coil to the distributor should send out a spark each time the points open - you can test this by removing the lead from the distributor, peeling back the rubber boot and holding the end of the lead about 1mm from a metal part of the engine (don't touch the end of the lead with your fingers or you will get a jolt!) - when you crank the engine you should see sparks between the lead and the engine. If you're not getting a spark, the coil, leads, points or condenser may be faulty.
_________________ Dave - 64 Nurburg White Morris 850 & 67 Morris Mini Deluxe (Bro's Car) Previous Rides - 62 Morris 850 (Sold '03 - Now 'Lulu-62') & 76 Clubman S (Sold '99 - SFW-863) + Too many other classics
