It is currently Fri Aug 01, 2025 3:11 am
 Post subject: Wiring
PostPosted: Thu Aug 13, 2009 6:54 pm
Hey, I have a question about some wiring on a 71 clubman with a 998cc.
Theres a wire coming from the Distributor, does this go to the coil and if so is it the +ve or -ve?
How many wires go to the coil?
We have the one from the distributor, a green wire and a white wire.
Any help would be great even some pictures if anyone has them.
Thanks
Blake
PostPosted: Thu Aug 13, 2009 7:52 pm
Assuming the car is Negative earth,
The wire coming from the distributor goes to the -ve terminal of the coil (this is the trigger wire and causes the coil to produce a spark when the points break).
The white wire should be the 12v supply (check with multimeter) - this goes to the positive on the coil.
I'm not sure about the green wire (can't find it on the wiring diagram), but does your car have a tachometer/rev counter? If so that's probably the sensor wire - not 100% but I think that also goes to the -ve terminal on the coil (but this depends on the tach itself).
+ Too many other classics
PostPosted: Thu Aug 13, 2009 9:34 pm
Oh ok thanks, we gave it a try.
Am i suppose to get a spark inside the distributor when we turn it over with the cap off?
PostPosted: Fri Aug 14, 2009 9:36 am
Not sure what you mean, there should be a small (hardly even noticable) spark at the points when they open. The lead that goes from the coil to the distributor should send out a spark each time the points open - you can test this by removing the lead from the distributor, peeling back the rubber boot and holding the end of the lead about 1mm from a metal part of the engine (don't touch the end of the lead with your fingers or you will get a jolt!) - when you crank the engine you should see sparks between the lead and the engine. If you're not getting a spark, the coil, leads, points or condenser may be faulty.
Users browsing this forum: Bing [Bot] and 90 guests
