It is currently Thu Aug 07, 2025 7:45 pm
 Post subject: 13 x 5.5 13 x 6
PostPosted: Tue Jul 14, 2009 8:19 pm
Hey all.
After seeing a few minis at the show ( which was a great event btw) on the weekend with 13's ive decided to go the same way... I think....
I know that for 13x7's to fit the guards have to be cut but just wondering if anyone can tell me if any body mods are needed to fit 13 x 5.5 or 13 x 6's??????????
Going on a 1275 LS which will be as low as possible with hi los....
Cheers...
1978 1275 LS silver 3rd palce mini Oz50 LS,SS,GT Class
1970 MORRIS MINI K 1100 3rd place mini50 pre '71 Class
Rover BBQ..... ;)
PostPosted: Tue Jul 14, 2009 8:42 pm
If you want to run really low, body mods will be needed.
Rim width makes jack all difference, since the only tyre size you will get is 175-50 R13
then you have to go on that.
If the car runs higher then mods may not be needed.
PostPosted: Tue Jul 14, 2009 9:55 pm
my van got 13x5.5 no body mods and no rubbing on full lock here is a pic
DVS K
Toad the Moke
Brutus the Ute
Mean Monster
Purple People Eater
PostPosted: Thu Jul 16, 2009 8:43 am
Hmmmmm...
Would have thought that the offset of the 13x7's would make a big differance..???????
Rover BBQ..... ;)
PostPosted: Thu Jul 16, 2009 8:45 am
REALXSBASS wrote:
Hmmmmm...
What are you asking?
PostPosted: Fri Jul 17, 2009 8:17 pm
i would have thought that a 13 x 7 would touch heaps more thsan a 13 x 5.5 because the offset on the 13x7 would be a lot more
Rover BBQ..... ;)
PostPosted: Fri Jul 17, 2009 8:23 pm
correct
PostPosted: Fri Aug 07, 2009 3:38 pm
Just back to the 13x5.5's, what is the profile of tyre req for these wheels. i know it is a 175/????R13.....
Rover BBQ..... ;)
PostPosted: Fri Aug 07, 2009 3:42 pm
175/50 13 is what you want.
Those tyres will fit from 5.5 to 7 inch rims, though the 7 inch is a stretch.
PostPosted: Fri Aug 07, 2009 3:57 pm
that's got a lot of height in the suspension, any lower at the front and it would rub
I reckon you should drive a car on 13"s before you go putting them on
PostPosted: Fri Aug 07, 2009 7:49 pm
when you put the engine in it that will give its real height
PostPosted: Mon Aug 10, 2009 10:10 am
does n e one know where I can get 175/50 r 13's around the s.e melb subs???? cheers
Rover BBQ..... ;)
PostPosted: Mon Aug 10, 2009 10:37 am
Try Frankston Tyrepower, they've always been able to find stuff for me.
Toby at mini spares and repairs has some new Simex 175/50/13s in stock too I think.
PostPosted: Fri Aug 14, 2009 3:55 pm
Hmmmmmmmmm... no one has any :shock:
Rover BBQ..... ;)
PostPosted: Fri Aug 14, 2009 3:58 pm
Harley, i think you`ll find that they will be "Sime" tyres
Users browsing this forum: 78Clubbie and 79 guests
