It is currently Sat Aug 23, 2025 11:09 pm
PostPosted: Tue Aug 18, 2009 5:52 pm
ive bought an electric fuel pump but i have no idea how to put it in and get it working. where should it be located?
do i need any extra fittings like fuel hoses/pipes?
i also need to Know about my eletric gauges. ive bought 3 smiths gauges (oil p., Volts, water temp) where can i get the fittings and wiring for these, i have also heard you can get a t-piece connection for the oil p and have a light in there too, where can i get all these bits and how do i wire them up?
thankyou,
Leighton
PostPosted: Tue Aug 18, 2009 5:56 pm
depends what type of car u got but electric check under the back subframe in the corner near the back left wheel
PostPosted: Tue Aug 18, 2009 5:58 pm
sorry i havent put it in yet, is it meant to go under the fuel tank?
PostPosted: Tue Aug 18, 2009 6:30 pm
yer on the outside of car jack the back up stick ya head under there and up in the cornere will be ya old one if u have electric
PostPosted: Tue Aug 18, 2009 6:33 pm
thats were it should be lol mine dont have a electric but that is were it is ment to go
PostPosted: Tue Aug 18, 2009 6:36 pm
I is a mookenik
ill post a pic for u when i get home mate. its not hard to do, took me about 15 mins to connect and wire up.
PostPosted: Tue Aug 18, 2009 7:17 pm
this is how i did mine....was told to use one rubber mount but i did two.
shes not wired up yet as i have no loom....but its one wire to earth and other to main power on ignition ie...turn key and she gets power.....well i think thats right ??
PostPosted: Tue Aug 18, 2009 9:12 pm
They are quieter if mounted on a Mini front exhaust pipe mounting.
The 2 bolt holes line up perfect... :P
PostPosted: Tue Aug 18, 2009 9:24 pm
ok thanks for the replies. do i need any extra fuel hose/pipe lengths?
PostPosted: Tue Aug 18, 2009 9:33 pm
Yes. 1 metre is plenty, get decent hoseclamps that fit properly (no stiff wormdrive ones).
I use USA made fuel hose, it doesn't go hard when using unleaded fuel.
PostPosted: Tue Aug 18, 2009 9:42 pm
thankyou for your help in both threads :wink:
