It is currently Mon Aug 04, 2025 1:30 am
PostPosted: Thu Sep 10, 2009 3:52 pm
Without much difficulty, I managed to remove a twin fuel tank (probably off a Cooper S) from my 66 Deluxe.
Now the problem is to cover the hole where the tank spout exited. I am not a MIG welder and am on a very tight budget.
Could I use fibre glass matting etc to cover this up? How solid will this be?
PostPosted: Thu Sep 10, 2009 4:00 pm
y not leave it in there ???
PostPosted: Thu Sep 10, 2009 4:01 pm
.... it aint original.
It is a de luxe, want it to look like a deluxe. :D
PostPosted: Thu Sep 10, 2009 4:41 pm
put it back in and wait till you can afford to have it fixed professionally, because the whole rear corner of the car will need to be repainted
I'd weld it up for you for a couple of slabs and the RH tank ;)
PostPosted: Thu Sep 10, 2009 6:17 pm
Speaking of filling holes.. Ive found a ton of holes *drilled @2mil* for self tappers and rivets. I can bronze these up? or is it just better to bog them?
Im actually starting to find more :( than :) pulled the chrome work off today.. not a single bloody piece didnt have rust on it.
grrrr
crap dont mean to hijack ya thread.. ill repost this once I open up a resto post on Isabelle.
PostPosted: Thu Sep 10, 2009 6:38 pm
"I'd weld it up for you for a couple of slabs and the RH tank"
At the price of right hand tanks isn't that being a bit greedy....
I did notice the smiley....
Cheers, Ian[/img]
PostPosted: Fri Sep 11, 2009 2:28 pm
just cut a neck off a damaged tank put a cap on it and use it to fill the hole
