It is currently Mon Aug 04, 2025 5:13 am
PostPosted: Sun Oct 11, 2009 6:51 pm
Hi all,
well i replaced the clutch today and i am not quite sure if wat i did was correct so would love to hear off someone who has done if before if i have done it correctly!!
I lined the A on the pressure plate to the 1/4 on the flywheel
Step 1 - Putting .........this thing...............on.
Step 2 - Putting clutch plate in
Step 3 - Clutch plate in place
Step 4 - Flywheel
Step 5 - flywheel view from top
Step 6 - locking nut thing and bolt
Step 7 - nut and bolt in place (i did tighten them up)
Step 8 - Pressure plate (all screws when completely through the sheet metal locking tabs as i heard if they dont it can cause sudder)
Step 9 - putting belhousing on
Step 10 - hoping it all went together correctly!!
I have also given the bellhousing a sand back and respray so it actualy does look nicer now, this was just so i could see whether or not i have done the clutch correctly!
if i did something wrong please tell me......if i didnt please tell me as well!!!
Thank you all!!!!
Hi-Ho Silver LS1275
PostPosted: Sun Oct 11, 2009 7:24 pm
Did you assemble and check the diaphragm spring was flat when all tightened down?
Did you 'lap' the flywheel to the crank and bed it in - tighten - rap with a rubber mallet - loosen the bolt and repeat 3 times
David L
PostPosted: Sun Oct 11, 2009 7:28 pm
No i didnt do either of those :lol: i guess my idea of taking pictures and putting it up here is working, i made sure everything i did could be undone just incase i was wrong!
I was speaking to aaron befgore and he mention what torque i did that main nut up to and i didnt no what was the appropriate number, is there any number or is it just making sure its pretty bloody tight?? at the moment its only spanner tight (i wasnt swing off the spanner either :p)
Hi-Ho Silver LS1275
PostPosted: Sun Oct 11, 2009 7:39 pm
Read this
http://www.minimania.com/web/SCatagory/CLUTCH/DisplayType/Technical%20Information/DisplayID/153/ArticleV.cfm
and this
http://www.calverst.com/cc110f.htm
David L
PostPosted: Wed Oct 14, 2009 2:52 pm
Mods rock!
Great set of Pics (did I say that right?). On a standard set up (which is what it looks like you have) the backing plate, flywheel and diaphram spring are indexed for balance. If you look very carefully at all the posts on the backing plate, one of them will be stamped 'A', this normally goes through the flywheel hole nearest your timing marks and again look carefully at the diaphram bolt holes and one of them will have 'A' again (or usually part of the letter). If you've not checked I would loose any sleep over it, but is is alway nice to put it back the way that it was intended.
PostPosted: Wed Oct 14, 2009 3:33 pm
dont know about that... the only thing i would sudgest is make sure you put a locking tab washer on your flywheel and make sure you torque it up properly.. also the presure plate needs thoese lock washes
wouldn't worry to much about that either, like GT said
you also dont need that bent clutch arm anymore.
*Reasonable pricing
*I come to you..
Jay: 0431404607
PostPosted: Wed Oct 14, 2009 3:37 pm
Whats the correct torque for the flywheel tho?
i no the flywheel and clutch plate had an "a" couldnt see any other on it tho
Hi-Ho Silver LS1275
PostPosted: Wed Oct 14, 2009 3:48 pm
152Nm/112lbf ft for the flywheel bolt
1965 Morris Mini Deluxe - 998cc SC12
PostPosted: Wed Oct 14, 2009 6:33 pm
I would lose the flywheel bolt locktab if fitted, they are made from too soft steel these days and can compress, causing the flywheel to come loose.
Use Loctite 262 on the bolt threads instead.
Works for me (and a certain well known Sydney Mini race engine builder).
:wink:
