It is currently Mon Aug 04, 2025 7:52 am
 Post subject: tight boot clips!?
PostPosted: Fri Nov 06, 2009 9:59 pm
I brought a set of boot rubber clips and they seem too big. The end just about fits in the hole but i have no chance of pushing the whole clip in its is pyshically too wide acroos the clips flat section!
Has anyone else had this issue or do i need to be more brutal, or slightly grind/file the clips??
PostPosted: Fri Nov 06, 2009 10:33 pm
You could hit them with...............NAH cant do it to ya :wink:
 Post subject: Re: tight boot clips!?
PostPosted: Fri Nov 06, 2009 10:38 pm
Yeah, I found that.
I wrestled with the little buggers for an hour before getting the sh1ts and gluing it in :roll:
I am hopeless at all things trimming,, I can usually defeat rubbers ... but in this case, no luck..
Users browsing this forum: No registered users and 111 guests
