It is currently Sun Aug 17, 2025 5:05 am
 Post subject: Steering Q
PostPosted: Sun Oct 11, 2009 5:59 pm
i was reverse parking my clubby today , as i was doing so i was turning the wheel being non power steering being hard an all , then all of a sudden a big snap and now my steering is stuffed feels disconected to a point either side then it starts steering in that direction ? any ideas?.
cheers kemal
PostPosted: Sun Oct 11, 2009 7:04 pm
Stop driving the car. If you need to take it to a mechanic get it towed or on a trailer. It is not safe.
Now the warning is over.
Try the pinch bolt that attaches the steering column to the rack. Is it loose? If not remove the steering column on check the splines on the rack and the column. These are most likely the problems, so should be where you look first.
And dont dry steer, turn the wheel while not moving, it kills the splines on the racks quickly.
Simplify and add lightness
PostPosted: Sun Oct 11, 2009 7:10 pm
something has broken big time and do not drive it. If you wish, jack it up and put on axle stand and see if you can see anything that should be connected. Id have a guess its the tierods to the rack or top or bottom joints. I'f you haven't had much experience get it to one of the Mini experts to fix it and have a good look around while your at it
PostPosted: Mon Oct 12, 2009 7:19 pm
took off the steering column , splines look worn out.its not my daily so doesnt get driven much
PostPosted: Wed Oct 14, 2009 7:48 pm
all fixed costed 80 bucks for a new column
PostPosted: Wed Oct 14, 2009 7:52 pm
good stuff Kemal
PostPosted: Wed Oct 14, 2009 8:01 pm
This happened to me years ago in my panel van in Brisbane. I was pulling out of a drive way in bowen hills, after picking up some demo tapes i had duplicated, for the trip home to Ipswich and she let go. I still thank God it happened then and not on the motor way. Would have been major carnage. Glad to hear your situation is all sorted kemal and that there was no carnage. :)
PostPosted: Thu Oct 15, 2009 8:17 pm
was quick to do aswell very happy, im finding it easier to get parts for my mini then my daihatsu rocky hehe
Users browsing this forum: No registered users and 263 guests
