It is currently Tue Jul 29, 2025 12:53 pm
PostPosted: Fri Oct 23, 2009 12:21 pm
Is it okay to run this pipe through the bulkhead with other wires nearby? or does it get hot enough that it might compromise *melt* the electrical wires?
PostPosted: Fri Oct 23, 2009 1:05 pm
Tomboss Breweros
Shouldn't get hot at all as oil doesn'f flow continuously, just pushes up a bit when pressure builds then back out as pressure drops.
Just make sure the pipe is insulated from the bulkhead, the last thing you want is an oil shower in the car.
kimini wrote:
Jimmyinamini wrote:
PostPosted: Fri Oct 23, 2009 1:57 pm
thanks mate.
PostPosted: Fri Oct 23, 2009 2:20 pm
Yeah,
And don't forget to tighten it properly, or the right dash card will get a little oily!!! :oops:
Cooper S Mk2
Cooper S Mk1
PostPosted: Sat Oct 24, 2009 12:10 am
and dont unwind the whole copper pipe, leave it wound and it will absorb most of the bumps and knocks
Users browsing this forum: Andosoft, Hawken and 93 guests
