It is currently Wed Jul 23, 2025 7:09 pm
 Post subject: Extractor/Exhaust repair
PostPosted: Sat Nov 07, 2009 3:07 pm
Took Ribena to a reputable repairer three days ago because I heard a leak in the extractors - needed a bit of a weld somewhere.
Picked the car up today and I'm not happy
1. The bonnet wouldn't close. I think some careless person opened the bonnet too far and effectively 'stretched' the hinges
2. It's still leaking.
As I was driving away, the boss was driving away in the other direction.
Needless to say, I will be taking it back and complaining like crazy. Jeez, when you pay $200 you expect the job done properly. For that sort of price, I could have a complete new system I would think. The one that's on is stainless so it's still in good condition - it's just the extractors that are getting a bit 'used' by now.
Not happy :x
Rod Image
PostPosted: Sat Nov 07, 2009 5:03 pm
so what did they repair mate?
if it was on part the manifold or the extractors yep you could buy them new cheaper.
same old crap though..
my dad tank had a hole needed a weld the guy wanted to acid clean it & weld it for 280 lol.
he could buy one new close to that.. so times it makes me wonder ;)
so what i have worked out shop around & ask how much to replace first then repair ;)
stumps them some times that's for sure
 Post subject: Welding ?
PostPosted: Sun Nov 08, 2009 6:58 am
A weld that leaks for $200... Gee how much do welds that don't leak cost then ?
"Let us remove your "SHORTS"
PostPosted: Sun Nov 08, 2009 9:17 am
I had a hole in my extractors welded up the other day for $10 from the local exhaust guys! Mind you, I took the extractors of, and took them in and ground the weld down myself.....but if you want something done properly....do it yourself!
Ryan Filippi
Minis In The Gong
[email protected]
www.minisinthegong.com.au
PostPosted: Sun Nov 08, 2009 11:57 am
that's a sad point you make there.
Its a lot of worry when you are unable to pay someone to fix a problem so you don't have to stress about it.
No one cares anymore, they just want your money.
blokeinamoke wrote:
PostPosted: Sun Nov 08, 2009 12:33 pm
It's so true. Sucks but it really is. It's either easy done in 4 weeks to fix something then turns
Into 8 weeks.
Or fix it in 5mins want top dollar with poor rushed workmanship.
I would fully be hitting them up. Say welder charges 80 an hour that's like 2.5 hrs work.
You can weld a lot in 2.5hrs I would say. Keep in mind that would include him removing extractors
And exhasut if he needed to.
PostPosted: Mon Nov 09, 2009 6:27 am
Quite correct - it did include taking them off and re-fitting BUT I had to provide my own gasket :) Ah well, things happen don't they.
Rod Image
