It is currently Mon Aug 18, 2025 4:23 am
PostPosted: Sun Nov 29, 2009 6:41 pm
Looks like a high tensile bolt - will one do as a substitute with a stack of washers as a spacer?
PostPosted: Sun Nov 29, 2009 7:04 pm
The standard ones are only a grade 5 bolt - not teribly 'tensile'. These are OK for normal to moderate road use. Anything more you might want to go to a better grade bolt.
There is a spacer, about 16 mm (5/8") long between the top arm and the shocker just to stop the body of the shock absorber banging in to the arm. Enough washers would also work OK.
Users browsing this forum: No registered users and 309 guests
