It is currently Sun Jul 27, 2025 8:36 pm
 Post subject: Stalling issue
PostPosted: Thu Dec 24, 2009 2:43 pm
Hello all.....
I have started taking my mini for small test drives around the block... and all is well until I turn right. I turn right and it stalls and takes a couple minutes to start again.
I don't think its a starving issue because the pump gets really noisy when its low and I haven't heard a peep....
any ideas?
blokeinamoke wrote:
PostPosted: Thu Dec 24, 2009 2:50 pm
Low float level? What carby?
PostPosted: Thu Dec 24, 2009 3:15 pm
1 3/4 SU
I was thinking that too......maybe to high? would that make it flood on turns? I will go have a look at it after
blokeinamoke wrote:
PostPosted: Thu Dec 24, 2009 6:53 pm
I had similiar issues. Turned out to be needle! But that would only be my thought!
(\_/)
(O.o) <CoPy> <) MaY oBtAiN wOrLd DoMiNaTiOn.
PostPosted: Thu Dec 24, 2009 6:56 pm
Just don`t turn right & problem is solved :-)
ok ok,,, sorry,,, couldn`t resist it :-)
most probably & commonly a float angle / level situation
PostPosted: Thu Dec 24, 2009 7:37 pm
I would also think it would be float level. :D
But you can't overlook a hidden electrical problem with problems when cornering on particular way. It might be something silly like a loose wire on an electric fuel pump or a coil wire that shorts when cornering. :shock:
PostPosted: Thu Dec 24, 2009 7:44 pm
totally agree & i was actually going to type all that too ,but it seemed to long ,,, & everyone knows i don`t like typing long responses :-)
PostPosted: Thu Dec 24, 2009 7:47 pm
That's alright, I don't like reading your long responses. :mrgreen: :lol:
PostPosted: Thu Dec 24, 2009 10:39 pm
thanks guys I will have a quick check of the power to the pump.
I will then refer to my Mini texts and insure the float level is correct....
I never really gave it that much thought because I didn't think the float bowl would empty and refill "that" often, and the fact that fuel is drawn from the bottom of the bowl... I wont put that much thought into it and just fix it.
thanks again eryone
blokeinamoke wrote:
Users browsing this forum: fuzzy-hair-man, Goldbrocade_62 and 95 guests
