It is currently Thu Aug 14, 2025 12:10 pm
PostPosted: Fri Jan 08, 2010 4:03 pm
I've got a set of Clubman Inertia reel seat belts that have been removed from a car. when removed they have wound so tight onto the spools they are not locked. They will not pull out as the locking mechanism kicks in.
Does anyone know the easiest way to repair the mechanism? Can they be taken apart?
Thanks,
HRS
PostPosted: Fri Jan 08, 2010 4:09 pm
You have to keep them upright to get them to unlock.
Have you tried mounting them in a car then trying it?
Cheers Pete
PostPosted: Fri Jan 08, 2010 6:33 pm
They need the reel to be pretty well horizontal before they will unlock. I'd grab the bracket bit in the vice, level it then try.
PostPosted: Fri Jan 08, 2010 8:09 pm
Thanks. I'll give that a try.
PostPosted: Fri Jan 08, 2010 9:18 pm
As well as having them dead upright you have to pull them out very gently when they are fully wound.
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Sat Jan 09, 2010 2:22 pm
They have released. Thanks guys for all your suggestions.
Things are so much easier once you know how!
HRS
Users browsing this forum: No registered users and 255 guests
