It is currently Fri Aug 15, 2025 12:08 am
 Post subject: 1100
PostPosted: Wed Jan 13, 2010 6:20 pm
Ok guys I got a 1100 bored out 40 thou with a re13 cam and a 344 diff got a standard head on ATM with double valve springs and 1.1/4 carbie planning on getting a bigger head for it the question is if I am sitting still and drop the cluch wile reving it should it spin the wheels ?? Cause it don't
 Post subject: Re: 1100
PostPosted: Wed Jan 13, 2010 7:04 pm
NAV-MAN
Yes you should unless you've got super sticky tyres on there. My 998 will spin my A008's a bit off the line if I get a bit too excited, and it'd probably do more except i don't want to bust my gearbox so tend to sacrifice the clutch, and if you want the gearbox and associated bits to last a while I suggest laying of the heavy handed launches.
PostPosted: Wed Jan 13, 2010 7:08 pm
Just had gear box redone but even if I rev the guts out of it and drop the clutch I get no spin its like the clutch just slips ???? And grips slowly
PostPosted: Wed Jan 13, 2010 7:33 pm
What clutch diaphragm did you put in- the 1098 had a green dot one stock that was too weak. You want the blue dot Cooper S one. 8)
It could also be the clutch assembly height isn't correct.
See http://www.minimania.com/web/DisplayID/ ... ticleV.cfm
PostPosted: Wed Jan 13, 2010 8:14 pm
Um all the clutch and stuff come out of my 998 motor which I pulled out to put new motor in
PostPosted: Wed Jan 13, 2010 8:50 pm
998 diaphragm has a weak spring too.
Like I said, just fit an S one, but make sure the clutch assembly is set up right.
After 4 years of people re-machining the backplates and flywheels, most are miles out, and clamping force is then much lower.
Users browsing this forum: No registered users and 226 guests
