It is currently Tue Aug 12, 2025 7:41 pm
Post new topic Reply to topic  [ 54 posts ]  Go to page 1, 2, 3, 4  Next
 Post subject: best bang for your buck
PostPosted: Thu Jan 14, 2010 11:46 am
hey guys
just after some advice on carbies, i am in need of upgrading my old 1 1/2' as i hav had ongoing problems with it. i am looking into twin 1 3/4 SUs, assuming that they are bigger are they the best performance wise? i have a rebuilt 1275cc engine.
what is the primary comparison between Webers and SUs??
Thanks
PostPosted: Thu Jan 14, 2010 11:52 am
I thought this was about Veterans cutting their Viagra tabs in half :roll:
PostPosted: Thu Jan 14, 2010 11:57 am
Carbs on their own will not give you any extra performance. All they will do is give you the potential to have more performance.
The performance gained is in the manifold.
So whatever carb you use dont bung it on a dodgy manifold.
And twin 1 3/4s would be a bit big for a stock 1275.
Simplify and add lightness
PostPosted: Thu Jan 14, 2010 11:58 am
but will it increase the power if i am upgrading from a single to a twin setup?
PostPosted: Thu Jan 14, 2010 12:01 pm
Milatsmadmini
best bet would be the standard twin 1 1/4's, or if your head has had enough work done to it, twin 1 1/2's.... that'll get it up and going... :wink:
twin 1 3/4's are a little too big for a daily car, more left for the fully fledged track eaters...
PostPosted: Thu Jan 14, 2010 12:04 pm
It depends on the intake manifold.
If you have a single on a really well flowing manifold, then put the twins on a cheapy chinese manifold you lose power and drivability.
Likewise if your using a stock single inlet manifold and upgrade to a twin carb performance one you will see more power.
But it wont be because of the extra carb.
PostPosted: Thu Jan 14, 2010 12:11 pm
assuming your primary consideration is performance?
what other work has been done to the motor? or what are you planning?
Why has no one mentioned weber/dellorto? Carbies of kings...
--Insert legal disclaimer here--
PostPosted: Thu Jan 14, 2010 12:17 pm
Yeah, I would agree... twin 1 3/4" probably a bit full on for a roadie..
The manifold does come into play a bit (but so does the head and rest of the motor and where and how you will be driving it most of the time), you want one that meets the demands of the motor, if it doesn't flow enough then you just rob yourself of potential power the whole way up the rev range but particularly as you reach the top.
As far as differences between Webers and SU's, well, the difference between a HIF44 and a 45DCOE is that (if everything is in order) you might get an extra 5hp out of a weber at the top end of the rev range... but with an SU, you will get more torque at lower rpm...
Webers can be tuned to run economically, but even so they are thirster than an SU... but they do sound awesome 8)
For a hot 1275 for the road I would suggest maybe a set 2X1 1/4" SU's, a HIF44 or 2X1 1/2" SU's...
But as was pointed out by Gareth_1330,, it depends on what has been done to the motor
PostPosted: Thu Jan 14, 2010 12:28 pm
well i havnt heard to much difference between the webers/dellortos to SUs
but an extra 5hp doesnt justify modifying the firewall...
the engine has an oversized cam with electronic dizzy rebored to 1310cc has been runny badly since built because of the carby and want this justified finally only thing is which way to swing
PostPosted: Thu Jan 14, 2010 12:38 pm
they used HIF44's on everything from the high compresion 998 Metro HLE thru to the Metro Turbo,, so I reckon for a roadie that they are a safe bet...
As far as far as manifolds for them go, I normaly use the MG Metro manifold as they perform better than some of the after market ones. But they are getting hard to find.
What ever you settle on, get the car dyno tuned or you wil never get the most out of it
PostPosted: Thu Jan 14, 2010 12:48 pm
Single 1 1/2 or 1 3/4 if its a stock 1275!!!!
PostPosted: Thu Jan 14, 2010 1:09 pm
I agree with some reservation.
I just love the sight of a couple of big jugs! :) :D :lol:
PostPosted: Thu Jan 14, 2010 1:19 pm
Big single 1 3/4 works well & is easy to tune, at a much better cost than twins.
PostPosted: Thu Jan 14, 2010 1:57 pm
thanks guys
the guys running SUs have you had running problems and problems tunning?
PostPosted: Thu Jan 14, 2010 2:08 pm
If an SU of any type is in good condition and set up properly for the motor its on, it will run fine. Getting said carb set up shouldn't be a major drama. Twins are a bit more involved but the same applies. What problems are you having with your HS4?
Kevin
Users browsing this forum: No registered users and 236 guests
