It is currently Mon Aug 04, 2025 5:16 am
PostPosted: Sun Jan 17, 2010 12:33 pm
Anyone know how i can repair this lead, it has come of in the dizzy?
can you solder it back on?
PostPosted: Sun Jan 17, 2010 2:17 pm
Mods rock!
Generally these ends are crimped on. If it has done this then it can be repaired but it is also usually a sign that the lead has had it's day and needs replacing anyway. A full set of new leads is only about $20 to $25 for OK standard ones.
PostPosted: Sun Jan 17, 2010 2:27 pm
Might he be also talking about the low tension one?
The description is a little vague as to which one is broken and how...
Pictures always help.
PostPosted: Sun Jan 17, 2010 2:51 pm
Mods rock!
ErrrUmmm....yeah, your right mick.
Pics please........
PostPosted: Sun Jan 17, 2010 3:09 pm
Sorry low tension lead.
PostPosted: Sun Jan 17, 2010 3:24 pm
Mods rock!
I take it that it is not a lucas 23 or 25D4 or anything electronic. In the range of 29D4 or 45D4, with a flying type lead.
Yes it can be soldered, however, it can easily be replaced. I guess that the reason it broke in the first place is because the plastic insulation has gone quite hard and become brittle.
Users browsing this forum: Bing [Bot] and 86 guests
