It is currently Mon Aug 18, 2025 1:11 pm
 Post subject: Austalloy Hydro Pump
PostPosted: Fri Jan 13, 2012 12:01 pm
Doing up my pump can anyone supply me with a pic of an original pump I need to fit the wheels to it and the hose colours have faded still works good though.
Thanks
1970 Mk 2 Cooper S
PostPosted: Fri Jan 13, 2012 10:18 pm
http://www.ausmini.com/forums/viewtopic ... oy&start=0
This could help. Maybe....
Image Image
PostPosted: Sat Jan 14, 2012 8:33 am
Thanks for the link I have seen that, what Im after is a pic of the legs with the wheels attached the rest I have done.
1970 Mk 2 Cooper S
PostPosted: Sat Jan 14, 2012 9:05 am
Heres some pics of my car being pumped up by Graeme Lord's in Wollongong. Not sure if it's same type of pump you are talking about but it looked pretty original.
Hope the pics help.
Phill
PostPosted: Sat Jan 14, 2012 9:38 am
Thanks for the pic Phil Im not sure if they are original wheels but I might have to go with something like that if nothing else comes forward. I cant even remember if they actually had wheels it does have carry handles front and back.
1970 Mk 2 Cooper S
PostPosted: Sat Jan 14, 2012 9:46 am
I have seen a few with wheels and I have seen a lot without wheels. The ones with wheels all seem to have a similar type of wheel (early Victa mower?) as well as having a handle on the back for wheeling them around.
I think they must have been made that way on some of them at some stage.
PostPosted: Mon Jan 16, 2012 5:29 pm
Mini is very original looking, came from my mechanic who has worked on minis since they were new (had two, sold me one). No wheels, but handles front and back so that you can pick it up....
1964 Morris "Cooper S" Group Nb Racer
1965 Morris 850
ex 1967 Morris Cooper S
ex 1969 Morris Van (Rover SPI running gear)
PostPosted: Mon Jan 16, 2012 6:47 pm
Thanks Number 86 as I suspected. I also worked on them when they were new its just that the grey matter has sagged a bit, anyway thanks for the info mine has the handles so will forget about some wheels
1970 Mk 2 Cooper S
PostPosted: Mon Jan 16, 2012 6:52 pm
I was thinking of wheels for my one. I was going to just make an axle that slips onto the rear legs with a handle that is just a pole attached to the axle.
Mind you, my one is missing its handles! :lol:
PostPosted: Mon Jan 16, 2012 7:49 pm
That sounds ok, I guess its about how far and often you have to move it, mine will most likely just sit proudly in the corner of the shed with very little use.
1970 Mk 2 Cooper S
PostPosted: Mon Jan 16, 2012 8:17 pm
For a busy workshop its a pretty understandable addition so I guess quite a few ended up like that
I reckon they look better without the wheels. Makes them look more like a Dalek. :)
