It is currently Mon Jul 28, 2025 12:42 am
PostPosted: Tue Apr 05, 2005 6:27 pm
Had a look at my front brake pads today (8.4" discs) and there is about 3mm of meat left on them. My father recons its 1mm that they change it at, and recons that its 1mm, but of course, I looked at it and it was more than that.
Should I be looking at changing them soon?
I've heard of "black stuff" pads being good for the road. They are from the same people who make "green stuff" and "red stuff" pads, they called APC or summit like that? Where would I get a set (I would imagine it's not a very "off the shelf" kinda part) and how much are they?
PostPosted: Tue Apr 05, 2005 6:39 pm
Not sure on the minmal pad thickness..
but that company your talking about is EBC:
http://www.ebcbrakes.com/Automotive.html
Do a search, it's been talked about before i'm sure..
PostPosted: Tue Apr 05, 2005 6:42 pm
Yer pads have been talked about, but I can't recall anything being said about minimum thickness... which is prolly cause I overlooked it, hehe.
Will you be changing them before or after a certain trip to Albury?
I'd start looking for new pads at around 2mm. If you're unsure, change em now.
PostPosted: Tue Apr 05, 2005 6:44 pm
Still got 3mm on em.
PostPosted: Tue Apr 05, 2005 6:59 pm
when you shoud change em depends on your driving and how well you maintain your car
only thing that has to be done is to change em before they get metal to metal
this is coming from a mechanic point of view
if a car gets serviced every 10 000k and won't have anything checked in between then 3mm might be the replacing time
but if the car is being worked on most of the time and has a wheel off most weekends then 1mm is prob the right amount to change em at
remember once they go metal to metal they will destroy the rotors very very quickly
pads are cheaper then rotors
PostPosted: Tue Apr 05, 2005 7:39 pm
Lets put it this way... i'll now be checking it on a regular basis now I know how much is left.
PostPosted: Tue Apr 05, 2005 7:42 pm
1mm is too close- there's danger of the pad adhesion to the plate being lost. 1.5 or 2mm is safer. :wink:
I have EBC Blackstuffs on Barney (wife's car). Also known as Street Kevlar. They are a good road pad, but no good for track work or real spirited driving. I faded them coming down Kurrajong Hill..
Greenstuffs are the go if you drive like I do.. :P
<edit> I used to be able to get them on line at www.autospeed.com but no more apparently. :x
Anybody know a source- other than the usual brake places that rip us all off? :?
PostPosted: Tue Apr 05, 2005 8:16 pm
I hardly really JUMP on the brakes, especially consistantly. Tho when I do, will the street kevlars bother me much?
I'm waiting for an email reply from a local EBC stockist.
PostPosted: Tue Apr 05, 2005 11:14 pm
for roadworthy certs the minimum is 1mm. but like the doc said that is cutting it a bit fine. i'd normaly change pads at 2 to 3 mm more if the owner has a history of not checking them and missing services etc.
cheers steve
Cheers Steve.
1973 south african mk3, 1275 +30 (1300), RE13 cam, hif44, mildy worked head with s sized valves, pulsar dizzy, 1.5:1 minispares forged rockers.
PostPosted: Wed Apr 06, 2005 1:04 am
What can happen if the pads get to low is the pistons can move in the calipers and jam, especially if they are a bit old. I have had them actually come out of the caliper in a transit van (work vehicle). Not a pleasant experience at all.
Chris
Everything I like is either
PostPosted: Wed Apr 06, 2005 9:54 am
I just got a set of Street Kevlars ($53.84) from autospeed last week and I'm pretty sure they also had the greenstuffs ($80 odd I think) listed too. They were for 7.5" disks though, not sure about 8.5's
PostPosted: Wed Apr 06, 2005 5:31 pm
Black Stuff (street kevlar) pads on MiniSpares
http://www.minispares.com/Product.aspx?pid=38315
That seem right price wise? I think I should be able to find some locally rather than paying for shipping.
PostPosted: Wed Apr 06, 2005 7:56 pm
Autospeed link won't show EBC pads this week. Try it..
I just get this: http://www.autospeed.com/cgi-bin/browse ... 1003600000
:cry:
PostPosted: Thu Apr 07, 2005 10:18 am
Well just got a reply back from a stockist from just down the road.
For DP127, which is the 8.4" pad part number, I was quoted $40 for street kevlar and $75 for green stuff.
Doesn't seem too bad, eh?
