It is currently Sat Jul 19, 2025 6:32 pm
 Post subject: Stripping block bolts
PostPosted: Sat Mar 13, 2010 12:11 pm
Does anyone else have problems stripping threads when assembling engines? ive stripped about 4 now.
Is it a case of running a thread tap down the thread and it's fixed?
Joe
Simplify and add lightness
PostPosted: Sat Mar 13, 2010 12:50 pm
Mods rock!
Oh yeah, it is easy to strip any thread! As for a repair, it depends on which threads you've stripped but it will most likely mean heli-coiling them to get them back.
PostPosted: Sat Mar 13, 2010 2:24 pm
I just got a tap and die set and fixed the threads I stripped before. I don't know why i didn't get one earlier.
PostPosted: Sat Mar 13, 2010 2:29 pm
i never have any trouble stripping threads.
i find it's one of the easiest things to do on an older car! :P
PostPosted: Sat Mar 13, 2010 2:53 pm
a little less vegemite might help.
Are you lubing them before hand ?
The threads wont really be Much good once you strip em and retap them to the former size as there wont be much metal left in there.
blokeinamoke wrote:
PostPosted: Sat Mar 13, 2010 2:58 pm
if you remove studs by locking two nuts together it's very easy to damage the threads - proper stud remover tools are the go
PostPosted: Sat Mar 13, 2010 5:46 pm
Mods rock!
If the threads are truely stripped then running a tap in to them will not restore them. It may just give you a couple of threads but it is a false sense of security.
PostPosted: Sat Mar 13, 2010 6:06 pm
I have built hundreds of engines and rarely strip threads. If you are having trouble then I suggest you stop doing bolts up so tight! You will be suprised of the small amount of torque required for some bolts to operate correctly.
Have a Nice Day.
PostPosted: Sat Mar 13, 2010 6:08 pm
Beware- the roller socket ones can chew the threads up more than 2 nuts ever will, if the stud is tight...
PostPosted: Sat Mar 13, 2010 7:34 pm
if you have stripped any thread it is no use running a tap down it as the metal has been stripped from the inside of the thread. Putting a helicoil in is the only way to go.
PostPosted: Sat Mar 13, 2010 8:54 pm
true - but they're perfect for head and rocker studs - short thread, plenty of shaft ;)
PostPosted: Sat Mar 13, 2010 9:02 pm
Tomboss Breweros
My tip to a mate who used to put my imperial bolts in his RX7 was "if you can't wind it in a few turns by hand it's either wrong or crossed, start again."
I ended up buying him a mix of metric bolts and a metric socket and spanner set, made his job a lot easier :roll:
kimini wrote:
Jimmyinamini wrote:
PostPosted: Sat Mar 13, 2010 9:05 pm
Mods rock!
Tombo wrote:
.........who used to put my imperial bolts in his RX7...............
Chinglish :?:
PostPosted: Sat Mar 13, 2010 9:14 pm
But then again, there are those that insist on following that age old mechanic's golden rule......
PostPosted: Sat Mar 13, 2010 9:40 pm
GT mowog wrote:
Chinglish :?:
No worse than some young blokes with Minis who manage to screw M8s into 5/16 UNF or UNC... :lol:
They should teach `em thread system differences at school or somewhere... :evil:
