It is currently Tue Jul 29, 2025 5:42 pm
Post new topic Reply to topic  [ 44 posts ]  Go to page 1, 2, 3  Next
PostPosted: Thu Apr 07, 2005 6:13 pm
My light has gone out in just the tacho only.. Do these take a bulb? or could it be a loose wiring?
I've pulled the surround off, but not sure where to go from there..I think there are screws that hold the whole thing on the dash, but to get at the souce of the light..I don't know..
any help?
PostPosted: Thu Apr 07, 2005 6:22 pm
there is a bulb for the tacho so it could have just blown
PostPosted: Thu Apr 07, 2005 6:42 pm
it would be much easier to fix if you pulled the whole cluster out.
72 Clubbie - Current project - Vauxhall C20XE 2000cc 16v 150hp.
78 Clubbie - Future project.
PostPosted: Thu Apr 07, 2005 6:44 pm
this is kinda on topic
but wat is the little red light under the speedo
its on all the time while driving i think
Nigel Morton/ Team Brickworx
never late in a 998
PostPosted: Thu Apr 07, 2005 8:57 pm
resident alien
resident alien
On the back of the gauge/cluster you have little black holders (about 5 or 6 in total). Just pull the one out behind that tacho and see if the bulb is blown. The bulbs come out of the holders of course. Swap them around to see whether or not it is the bulb or wiring.
PostPosted: Thu Apr 07, 2005 8:59 pm
Be careful removing/replacing those bulb holders- it's pretty fragile how they contact the PCB strip.. :cry:
PostPosted: Thu Apr 07, 2005 9:39 pm
the 'printed circuit' joint between the fuel/temp pod and the tacho pod is very fragile. It could be that this part of your printed curcuit has perished on yours....which means that tacho light won't illuminate :mrgreen:
PostPosted: Thu Apr 07, 2005 9:42 pm
Yep Yep i'm sure ALL Clubby owners have spotted this.
Its at the bottom of the speedo, and is tinted red.
I dont think theres a globe behind it - so what is it?
Its like the high beam thing, but red, and at the bottom of the speedo.
Anyone?
PostPosted: Thu Apr 07, 2005 9:46 pm
yeah ive noticed this and it is for nothin, however there is a spot behind
in (or is that the tacho one) for a bulb to go in, so maybe it is jusst soomething
the english minis may of had? also the one on the tacho is purple i think....
PostPosted: Thu Apr 07, 2005 9:52 pm
i got one of those lights too under the tacho purple light on all the time :?
PostPosted: Thu Apr 07, 2005 9:53 pm
maybe it means your light are on :wink:
PostPosted: Thu Apr 07, 2005 9:56 pm
there shouldnt be either one of those lights on unless someone has put a bulb in, and prob for a reason, is there any wires?
PostPosted: Thu Apr 07, 2005 9:59 pm
there are no wires or bulb at the bottom of the tacho just a hole for one but that light is on somehow :?
PostPosted: Thu Apr 07, 2005 10:06 pm
weired... :?
PostPosted: Thu Apr 07, 2005 10:45 pm
that spare light spot is there so you can hook up your shift light :D
josh dont worrie about replacing your globe, just get a tacho like mine :D
http://cgi.ebay.com.au/ws/eBayISAPI.dll ... RK:MEWA:IT
1974 Moke - 998cc
