Not much difference really. Speaking of blocks:
1275A+ series-
Bad points:
Castings are porous near the bores, so most were factory sleeved.
Water jacket cores are misaligned with bores.
Not many about in Oz, apart from late Mokes and Rovers.
Good points:
A bit lighter
A bit stronger (in places)
A+ cranks are stronger (supposedly) than the big journal A series.
Heads flow better stock but don't mod as well as an A series due to port size/shape.
1275 A series-
Good points:
Thicker castings around the bores, they bore big better.
Still plenty about (non-S)
Bad points:
There's a hole above the centre main bearing on thick flange blocks, but the jury is out on whether it matters. many of em are racing, no prob.
Early S blocks had a weak casting around the centre main bearing.
12G1505 big journal cranks tend to crack.
At the end of the day though all the whirly bits are interchangeable, for a high performance road motor it don't matter a rat's, IMO.
I'm running a Morris 1300 auto block with Cooper S crank and rods in it.
