It is currently Fri Aug 15, 2025 5:27 pm
PostPosted: Mon Mar 29, 2010 6:23 pm
If you have bought Hi Lo's from Minisport in the UK: they come with a black plastic cap on the end of the cone. Do I take this off or fit the hi lo with it?
It fits with or without it in! :oops:
Regards,
Mike
"He who dies with the most toys wins."
PostPosted: Mon Mar 29, 2010 7:38 pm
pic? can't see the rubber cone mounting face of the hilo in the picture of them on the website
you're not talking about this bit are you? if so, then yes, the cup stays on there - it's called a knuckle
PostPosted: Mon Mar 29, 2010 7:49 pm
1/2 fill the cones with some good grease too stops corrosion over time
PostPosted: Mon Mar 29, 2010 8:52 pm
Leave 'em on... They help to keep the threads from rusting up...
 Post subject: Hi los
PostPosted: Mon Mar 29, 2010 11:11 pm
It's not the knuckle I'm talking about - it's the other end that you can't see in the picture.
Consensus seems to be leave them in as they help prevent water getting into the cone thereby preventing corrosion. Plus, grease absolutely everything!
Thanks... :D
Regards,
Mike
PostPosted: Wed Mar 31, 2010 4:23 pm
For the record....Minisport say leave em on.
Big night of greasing-up ahead - and then I might work on the subframe :D
Regards,
Mike
Users browsing this forum: No registered users and 253 guests
