It is currently Fri Aug 08, 2025 4:30 pm
 Post subject: Burnt valve?
PostPosted: Wed Mar 31, 2010 11:47 pm
Tomboss Breweros
Driving home from work tonight my clubby broke :cry:
It started with a noise a bit like a stray spark, but only under load, this quickly turned to a loud ticking coupled with rough running and a lack of power.
Only noisy under load.
So i pulled over and had a closer listen, when i rev it stationary it makes a sharp pop/tick kind of noise through the carby. To me this is suggesting an intake valve problem but i have never seen one burn, only exhausts up till now.
I'm going to do some testing tomorrow and find out what it is.
Fingers crossed it might be as simple as a riding tappet.
kimini wrote:
Jimmyinamini wrote:
PostPosted: Thu Apr 01, 2010 7:37 am
Intake valves don't burn, but they can stick in the guides.
If it's spitting out the carby rhythmically, I'd pull the head off.
PostPosted: Thu Apr 01, 2010 2:13 pm
Tomboss Breweros
Tests showed a blown gasket between 1 - 2.
Time to get rid of the bolts and fit some new studs....
kimini wrote:
Jimmyinamini wrote:
PostPosted: Thu Apr 01, 2010 8:56 pm
what type of head gasket was it???
hee hee,,,sorry, couldn`t help it
PostPosted: Thu Apr 01, 2010 10:43 pm
Tomboss Breweros
I have no secrets, it is one of those aluminium colored ones. I'm not a big fan of them so i'm putting a monotorque, never had an issue with them :wink:
But there could be an issue with the old re-re-re-used bolts, i've never been too sure about the torque required for them either due to the coarse thread.
kimini wrote:
Jimmyinamini wrote:
PostPosted: Fri Apr 02, 2010 7:21 am
Those old head bolts are bad news, they are all brittle now. They snap off at top of block.
Get thee some proper studs and nuts.. :wink:
PostPosted: Fri Apr 02, 2010 8:37 pm
Tomboss Breweros
Yesterday got a new stud, nut and washer set. Opened it up today and found this. Now this is the gasket that blew to coolant November last year and 90% re-sealed itself, got my moneys worth :roll:
1-2 clearly blown through, 3-4 only had the fire ring, no fibre material, 2 and 3 both leaking through to coolant, and underneath 1 and 4 leaking through to coolant too :lol: Some sort of record for me..
kimini wrote:
Jimmyinamini wrote:
