smiths tacho wiring https://www.ausmini.com/forums/viewtopic.php?f=2&t=62168 |
Author: | wolfmini [ Thu Apr 01, 2010 7:33 pm ] |
Post subject: | smiths tacho wiring |
Hi, i took off my smiths tacho to relocate it and cant get it working again. it is one of those current sensing types. the loop wire sits in a plastic block, does this just need to be clamped down close to the sensor? it has power and earthed, its just not picking up the signal. i have tested the wire and has 0 ohms any ideas? or pics of the rear of a tacho? cheers ryan |
Author: | VulcanBB18 [ Thu Apr 01, 2010 7:36 pm ] |
Search is your friend? ![]() 2nd page in chat, seems like some good info there http://www.ausmini.com/forums/viewtopic.php?t=62137 hth cheers Jacob |
Author: | wolfmini [ Thu Apr 01, 2010 7:40 pm ] |
cheers, im having problems with the search on ausmini. just started this last week, but ill follow the link |
Author: | Mokesta [ Thu Apr 01, 2010 8:25 pm ] |
In a similar vein, what have I done wrong if my tacho needle rises and falls with the indicator flashes? M |
Author: | wolfmini [ Thu Apr 01, 2010 9:20 pm ] |
normally that would mean a bad earth mokesta, i don't know how but i think my tacho is stuffed, anyone want to sell one? |
Author: | Mick [ Thu Apr 01, 2010 9:42 pm ] |
Try looping the sensing wire from your coil in the opposite direction through the pickup. If you've connected +ve and -ve the right way around, this is the other thing to check. |
Author: | brett [ Fri Apr 02, 2010 2:22 pm ] |
i had that issue check that the cable from the coil to dist hasnt been swapped around. i swapped mine and worked great! |
Author: | wolfmini [ Fri Apr 02, 2010 6:29 pm ] |
yep got it working, wires the wrong way around. thanks for your help, i'll take some pics after the weekend and post them! |
