It is currently Sat Aug 16, 2025 10:01 am
 Post subject: Heater resto question
PostPosted: Tue May 04, 2010 11:58 pm
The Mini I bought for a resto ('78 Clubman) had no heater parts with it but I have pulled out the heater from a Clubbie which had been sitting out in a paddock for a few years. Amazingly the fan still works and the matrix has been given to a radiator shop to get it rodded out & tested. I have also ordered a universal heater tap to replace the one that is completely corroded and ceased. All brackets have been removed (rivets drilled out), sanded and repainted.
This is the heater as removed (click for bigger pic) :
However...
I need to know what the air direction flap needs to get refurbished (what does a new one look like?) and whether it's possible (and how) to remove the flap from the casing?
Also - what "goo" do I use to seal the two halves back together? Is had some kind of black rubberised sealer when I took it apart.
-Alan
PostPosted: Wed May 05, 2010 7:47 am
I know the black stuff you mean, but sorry im not sure what you should use fr that, but the flap just has some very thin foam glued to it
PostPosted: Wed May 05, 2010 8:23 am
You can get the self adhesive foam sheets (about A4 size I think) and cut it to fit with scissors from Clarke Rubber. Comes in various thicknesses to suit your needs. Cant help with the black glue, I've only done a roundie heater.
Flute - 68 MK I Cooper S
Member: VMCI #2474
PostPosted: Wed May 05, 2010 2:47 pm
Bah! Just got a call from the radiator place and the core/matrix is blocked to heck and is pretty stuffed :( Looking for a decent replacement now...
-Alan
PostPosted: Wed May 05, 2010 5:47 pm
Mearcat wrote:
the matrix has been given to a radiator shop to get it rodded out & tested..
So its wrecked because its blocked?? Isnt that the whole reason for getting it rodded?
What did the radiator shop expect to find?
PostPosted: Wed May 05, 2010 5:51 pm
They probably expected their rods to be able to poke the gunk out. If they can't get the rods through the core it means that they are really blocked and it needs a new core.
They can only do so much, they can't perform miracles.
PostPosted: Wed May 05, 2010 5:53 pm
They rodded it out (mostly) and each time they pressure tested it, another leak appeared and just kept blowing holes in it :?
I have already found a good replacement fortunately, but will still need to fix up the foam around the core & air direction flap later.
-Alan
Ahh ok.. i understand now
PostPosted: Thu May 06, 2010 1:47 am
Rare spares sells what looks like the right one for about $70. Saves on mucking around trying to adapt it. Will get one soon and post about it.
Alec
PostPosted: Thu May 06, 2010 11:37 am
I got this one for $27 and only thing it needs is a 90deg bend in the heater pipe (s per Wild willy's thread in the How To section). Very little mucking around required.
-Alan
Users browsing this forum: No registered users and 318 guests
