It is currently Fri Jul 18, 2025 9:02 pm
PostPosted: Thu May 20, 2010 9:29 pm
Are the hydro rear trailing arms the same as the rubber cone arms??
Interchangeable??
Minimad
You can take the boy out of the racer.........but not the racer out of the boy!
PostPosted: Thu May 20, 2010 9:31 pm
No. They are different and not readily interchangable.
PostPosted: Thu May 20, 2010 9:32 pm
Nope the position of the knuckle is different, also the brake pipe setup is different, and hydro arms have a bump stop on top.
Also the handbrake bellcrank pivot setup is a bit different.
That said, it is possible to use hydro arms in a dry racecar with hi-los, according to Justminis.
PostPosted: Thu May 20, 2010 9:36 pm
Thanks.. Won't bother keeping them :o
Minimad
PostPosted: Thu May 20, 2010 9:58 pm
As he said; a set of Hilos is all you need.
Cheers, Ian
PostPosted: Fri May 21, 2010 7:12 am
Stub axle needs to be changed too, need a press, for the lower shock mount. Not the only way to do it tho.
Steve
PostPosted: Fri May 21, 2010 8:41 am
You can cut it off flush then drill and tap 3/8 UNF for a high tensile bolt. Works even better with Koni shocks (can then adjust em on the car).
