It is currently Sun Aug 03, 2025 2:43 am
PostPosted: Mon May 24, 2010 10:17 pm
here is the deal pump the pedal and select gears easily
pump the pedal and leave it for 2 mins push clutch in again and gears can not be selected
what do you guys reckon :?
PostPosted: Mon May 24, 2010 10:18 pm
Tomboss Breweros
Air
kimini wrote:
Jimmyinamini wrote:
PostPosted: Mon May 24, 2010 10:23 pm
Spiders
PostPosted: Mon May 24, 2010 10:24 pm
ok another 30 pumps it did sound like it was crackling a bit still
PostPosted: Mon May 24, 2010 10:34 pm
Tomboss Breweros
Maybe it's picking up air through one of the seals.
kimini wrote:
Jimmyinamini wrote:
PostPosted: Mon May 24, 2010 10:36 pm
gotta hold yer tongue right
PostPosted: Mon May 24, 2010 10:39 pm
what seals how do i find this out :?
you could be right simon ill give that a go to
PostPosted: Mon May 24, 2010 10:42 pm
PostPosted: Mon May 24, 2010 10:44 pm
^^^^^^^^^^^^ :lol: :lol: :lol:
PostPosted: Tue May 25, 2010 6:49 am
Mods rock!
Most likely your slave
PostPosted: Tue May 25, 2010 7:46 am
i would say u have a leak some were check ya line that goes to ya slave cylinder c if it has any holes or if it is leaking
PostPosted: Tue May 25, 2010 11:33 am
I had a similar problem, my slave cylinder was pitted with rust and letting air in.
So, i replaced the slave and rekitted the MC - problem solved
You're so square
Baby I don't care
PostPosted: Tue May 25, 2010 12:01 pm
If the seals in the slave are gone it should be leaking into the rubber boot and will eventually drip. If the MC seal is gone the fluid will stay in the reservoir or possibly leak down onto the pedals inside the car.
Pete
PostPosted: Tue May 25, 2010 4:39 pm
I would go the whole hog and fit new seals in the master cylinder, slave cylinder and fit a new hose.
That way all the perishable bits are all new and should give reliable service for a long time.
PostPosted: Tue May 25, 2010 6:56 pm
Try just bleeding the slave first.... Maybe check the adjustment ... do you have a return spring??
Cheers, Ian
